Drywall And Kerdi Or CBU? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 07:50 AM   #1
Rewards Points: 590
Drywall and Kerdi or CBU?
Bathroom shower tub area with marble tiles.
Should I use drywall and Kerdi or plastic barrier and CBU? Which is easier?
noone is offline   Reply With Quote
Old 09-04-2012, 12:47 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Is this a shower stall or tub? Tub you use cbu & stall you use uncupling membrane like kerdi.
JetSwet is offline   Reply With Quote
Old 09-04-2012, 01:07 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Noone,
Sorry Jet got it a little backwards, I'm sure he just miss understood the question.
I believe the very best way to waterproof your tub enclosure is with a the surface membrane method.
Drywall with Kerdi is as good as any other substrate. If for some reason you feel un sure, you can use a CBU as the base and apply the membrane over that. Use a real concrete board though, many people have trouble with fiber/cement boards such as Hardie.
The old method will work too, but why use it when the surface membrane method is sooooo much better.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
GBrackins (09-04-2012)
Old 09-04-2012, 03:57 PM   #4
Rewards Points: 590
I just wanted to double check. Seems like kerdi is more work, but if that's the way it should be done to be done properly, that works for me.
Thanks!
Old 09-04-2012, 04:22 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
Well sure....... it's more work and more $$$.
With a surface membrane, nothing behind it gets wet. With all other methods the substrate gets wet/damp if moisture gets in. (Remember, tile and grout does not make anything waterproof). The paper/plastic on the studs is only a vapor retarder not a waterproofing. If done right it can work well too, just use real CBU and thinset (powder) adhesive).
Jaz
Old 09-04-2012, 05:55 PM   #6
Rewards Points: 590
Jaz
Thanks. I'm still debating on whether the extra expense and labor involved in Kerdi is worth it.
I just ripped out a 16 year old shower and it was installed with green board on the studs and cement board nailed on top if it with porcelain tiles on top. There was absolutely no leakage whatsoever.
I would be interested to know what materials are used today for a CBU install. What kind of plastic and what kind of cement board.
Old 09-04-2012, 06:14 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Like I was trying to say in prior post is that if you have a tub most likely you will install cbu, backer board holds to studs better then sheetrock and in my case a better tile bond as well. The reason for kerdi is the ability to lap the top and bottom corner seams like paper. So really you will have to buy sheet rock and kerdi as pose to just cbu. You can also red guard the cbu as well for better protection.
This is just my take on installs, kerdi is a wast or money because using it only on walls is not really what it's meant for. And tile and grout is what makes your shower water proof & that's the hole reason also that it looks much nicer then Fiberglas tub walls.
Old 09-04-2012, 07:54 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 388
There's a bunch of ways to do a tub enclosure and have it last a long time.
Wallboard, either regular or moisture resistant with no waterproofing system over it is not a good method. Wallboards with concrete backer over it then the tiles is also not an approved method. Can it work? Yes it can, heck I used to do it that way years ago to imitate a "real" "mud" job when using basic tiles that had mud bullnose to match. Those days are gone forever.
Since then surface waterproofing products have been developed because of the many, many failures when wallboards, mastic and other poor choices were made to cut corners. Using surface membranes to prevent the substrate from getting wet and at the same time preventing vapor from entering the wall cavities is smart and easy to do.
For a tub enclosure I would have no problem skipping Kerdi and using a liquid membrane instead. Tub enclosures are not as critical as showers so if you wanna save $50 bucks, go ahead. However using plastic or tarpaper on the studs then concrete backer makes little sense to me. You'll have a tough time getting it sealed right, and why would you think it's ok for the concrete backer to get wet?
What? No, it's to make a waterproof tile installation.
Floors, walls, ceilings, Kerdi (or any membrane) doesn't care where it's used.
OMG, you'd think after a few weeks of being here and thinking about it for a few seconds you'd know better that that. A ridiculous statement right there.
Jaz
Old 09-04-2012, 08:09 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
What can I say Jaz I'm just a very cynical tiler.
Old 09-04-2012, 08:13 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 388
Tiler? You're a tiler? NO WAY!
Jaz
Old 09-04-2012, 08:22 PM   #11
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
I love getting a rise out of ya Jaz! Lol
Old 09-04-2012, 08:26 PM   #12
Pro
JetSwet's Avatar
Rewards Points: 502
Ok let's try again, I come along and botch the posts just so I can learn more from you Jaz!
Old 09-04-2012, 08:34 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 388
yes, and you do it so often. OK, tell us, you used to me a carpenter right? What else can it be?
Jaz
Old 09-04-2012, 08:48 PM   #14
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
I guess carpenters can't be tilers huh
Maintenance, plumbing and carpentry?.....I'm jaded! I wasn't taught correctly on the tile, gggrrr! Lol
Old 09-04-2012, 09:12 PM   #15
Tileguy
JazMan's Avatar
Rewards Points: 388
Finally...a correct statement! Keep trying though. All you gotta do is a little searching, read some labels and you'll be surprised what you might learn.
Jaz
JetSwet (09-04-2012)
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Drywall Install - Alcove Tub monkeystomach Building & Construction 9 12-17-2010 07:38 AM
Bathroom floor - Kerdi Band for Ditra / drywall joint? Airgibson Flooring 12 08-04-2010 09:33 PM
drywall potential problem mmhendrie Drywall & Plaster 8 04-04-2009 08:23 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
