Drop In Spa Bathtub - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 12:54 AM   #1
drop in spa bathtub
Im getting ready to tile around a drop in tub. I need to find a way to create access doors for the water shutoffs and blower/heater. Note, i have to tile these doors and pretty much make them seem like they dont exist. Any suggestions?
M Frey is offline   Reply With Quote
Old 08-03-2011, 07:35 AM   #2
DIY staff
Rewards Points: 7,174
I moved this thread to 'tile'---You will get better exposure here.
I don't cut the ports until the tile is set,but not grouted---then,using a multi tool,I cut the opening and use magnetic catches to hold the wood/tile back into position.
grout matching caulk will fill the gap and be easy enough to remove,years from now,when access is needed.
Old 08-03-2011, 11:23 AM   #3
Thank you for your advice, i have the magnetic tabs. Im just not sure that they will hold well enough. I will give it a shot.
Old 06-11-2012, 02:41 PM   #4
We had to remove tiles from the front of a tub to access and replace the faucet. I would like to put an access door that matches the other cabinets. It is easy to find the door, but how do we install it without screws showing? Are there clamps that can be used on the inside?
Thank you for any advice.
ataraschi is offline   Reply With Quote
Old 06-11-2012, 03:28 PM   #5
DIY staff
European style spring closing hinges might work---
Closet door spring clips might do--look in the cabinet hardware section of one of the big stores---
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 12:39 PM
o I really need a drop ceiling over my bathtub? chkaryti Kitchen & Bath Remodeling 2 11-13-2009 06:09 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
