Drain Trim - Thin Set Or Grout? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-05-2014, 02:02 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 776
Drain Trim - Thin Set or Grout?
I'm doing the floor of the 1st floor shower now.
I have a square trim to go with the drain. Do I set it in thin set or grout?
I left some of the tiles out that are around it until I know exactly how to do it.
ddawg16 is online now   Reply With Quote
Old 08-05-2014, 05:53 AM   #2
Rewards Points: 4,780
The first thing I notice is that your shower doesn't seem to have any kind of waterproofing. But normally anything that needs to be set and adhered in place should be set in thinset. Grout is for filling cracks.
jeffnc is offline   Reply With Quote
Old 08-05-2014, 06:08 AM   #3
DIY staff
Rewards Points: 7,174
could you tell me more about this 'trim'--?? If it is tile--then thinset---where is the drain cover? Is it round or square?
Old 08-05-2014, 10:30 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 776
Oh yea....you guys on the east coast are not used to how we do it here.
Remember? Hot Mop? Then a sloped mortar bed (that is the grey you see) and then the tile on top of that.
The trim ring is a square stainless steel trim with a hole in the center the size of the drain.
I'll take pics tonight when I get home.
Old 08-05-2014, 11:59 AM   #5
So you "hot mopped" the walls, which waterproofs them? If so, did you then pierce the coating when you screwed the cement board onto it?
Old 08-05-2014, 01:07 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 776
Man....you East coast guys....don't know nothn'....
Just kidding....
Hot mop is the most common method in the south west. We don't have the cold weather you do so it's a very reliable way.
Here is what the hot mop looks like right after it's done.
We then layer tar paper on the walls as the moisture barrier. Yes, the cement board screws go through the tar paper. But it also tends to self seal. The hot mop goes up over 12" from the bottom. If you get moisture up that high, you have bigger issues.
As you can see in this photo...the tar paper is below the installed sheet of hardibacker. Most people use 15lb. I used 30lb.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
123pugsy (08-05-2014), oh'mike (08-05-2014)
Old 08-05-2014, 10:30 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 776
Here is the pic of the trim
Old 08-05-2014, 10:39 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 346
I don't know the answer to your question, but why didn't you just buy a square grate?
Old 08-06-2014, 12:01 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That works! Install it with thinset. Once the tile is in place and grouted, and the tile is caulked to the trim, it isn't going anywhere.
XXX
Old 08-06-2014, 12:24 AM   #10
Not really sure I understand that picture. Am I seeing that right? Is that 2x12 lumber you've "blocked" in all around the bottom 12" of the shower frame? In other words, you cut a piece of that lumber to fit between every stud in the shower frame? And then notched it out for electrical boxes and pipes? And then "mopped" some waterproofing ingredient on it? And then after that put cement board over it all?
I mean, I just can't believe you go to all that trouble - that is so much work.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 10:11 AM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 10:59 AM
Tile Grout in Bathtub drain naitek Plumbing 1 09-01-2006 08:33 AM
