Do I Need To Use A Batten Board For The First Rows Of Tile? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 01:59 AM   #1
Rewards Points: 156
Do I need to use a batten board for the first rows of tile?
Hey guys I am gettting to tile in the next few days. I am doing the bathtub walls x3. I am using 8" wide tile by 18" long and I am going to by laying them verticle in a subway pattern. My question is can I just start the tile off the edge of the tub with say a 1/8" spacer under the tile which would be placed on the tub. The tub is 100% level on all 4 ends. Or would I need to go up say 18 1/8th and install the batten then go up from there and finish out the bottom section last. Thanks
Pictures to follow when this is complete.
ryan5068 is offline   Reply With Quote
Old 07-10-2010, 06:34 PM   #2
DIY staff
Rewards Points: 7,174
You will want to install a ledger board on the three walls--your tub is not level--I promise you that.
The tub tiles will be cut to fit the surface of the tub.
Make sure the ledger is less than 18 inches.---This comes from experience--you may have the first ever perfectly level tub.
---Mike--
Old 07-11-2010, 07:31 AM   #3
Rewards Points: 156
Well I am confused on how to do a ledger board when I have 2 tile heights at the base I am basically going to have 8" then 18" then 8" and so on. So do I start with the shorter ledger board first (closest to the tub) then get a row of tiles in so it would look like this (imagine the "l" is 1 tile 8x18)
l l l l l l
There is a space there indicating an 8 1/4" space for the other tile to slide into. Is that how you would do it. Basically will I have 2 levels of ledger board. If so when do I put the 2nd level up as soon as the first tile row of tile is laid.
Old 07-11-2010, 07:34 AM   #4
Rewards Points: 156
Or would I draw a snap line to make sure it is level then cut each ledger board down to 8" or shorter and stager the boards as the tile will be laid which would be every other one 9-18-9-18-9 etc from the tub. Man I hope this is making some sense!! I am using 1/8 spacing so my tolerance is pretty tight.
Old 07-11-2010, 08:27 AM   #5
DIY staff
You would pick a difficult layout for your first job!
I'd snap out the two different start lines ---then use small nails or screws to keep the tiles in that row from sliding.
If you have waterproofed the board-- dab some water proofing into the holes after the nails are removed.
Using a ledger will not work in this situation---this will add a little extra time to your tile setting.
Take some pictures as you work--it will be fun to see the progress.----Mike---
drtbk4ever (07-16-2010)
Old 07-12-2010, 09:47 AM   #6
Rewards Points: 156
It is a difficult layout kind of. My wife said, "well this is how I want it done." so the true DIY'r said, "yeah what the hell, we can do that." Anyway instead of going every other one we decided on doing a random pattern of vertical. We placed the tiles and the ground and measured everything out and it looks sweet on the ground. We moved over to the wall last night and got half the wall done and it looks excellent so far! I plan on having the back wall done tonight or tomorrow and I will snap some photos then. Now I do have a question mike. When I butt the end walls up with the back wall do I grout the corners or use the matching caulk that I purchased from Thetileshop. I was more nervous starting this project than I was to even get married! Thanks
The Following User Says Thank You to ryan5068 For This Useful Post:
oh'mike (07-13-2010)
Old 07-13-2010, 08:07 PM   #7
DIY staff
The mating surfaces always need to be caulked---If the grout maker has a color match--that is usually the best choice.
Old 07-16-2010, 06:41 AM   #8
Rewards Points: 156
hey mike check out my profile I got some of the pics up from my tiling job. I think it turned out excellent for my first one. Let me know what you think. We are going to grout on Sunday and get all the accessories put on later in the week. Flooring is next.
Old 07-16-2010, 07:41 AM   #9
DIY staff
Look good!!!!
Your camera 'curved' the side walls---at first I was amazed that you could set the tiles so nicely on a bowed wall.----Mike---
Old 07-16-2010, 07:55 AM   #10
Rewards Points: 156
yeah that is an odd picture with the walls like that. Trust me they are straight! Thanks again for your help. I gain confidence when I come on here and get good trusted answers to my questions. More questions are surely to come!
Thanks again
oh'mike (07-16-2010)
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 04:17 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
tile backer board yudamann Flooring 1 06-29-2006 08:53 PM
