Do I Need To Shim With Tub Surround? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 01:20 PM   #1
Do I need to shim with tub surround?
when placing the tile against the tub (I'd like to start there once I snap a line and forget the batten), do I place a 1/8 inch shim under the tile. using 12 x 12. Also I'm setting the back of the tub against the long wall first, how close do I get to the actual wall at the corners.
Jewelie is offline   Reply With Quote
Old 12-13-2009, 05:16 PM   #2
Remodeling Contractor
The joint at the corner should be the same spacing of the joints everywhere else. But caulk this joint and along the tub edge, do not use grout.
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
I made a mistake and put in the tub surround early. Need plumbing help!! utilitylocator Plumbing 7 02-01-2009 09:39 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
