Do I Have To Remove Old Adhesive Glue On Wall For New Ceramic With Glue? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 07:06 PM   #1
do i have to remove old adhesive glue on wall for new ceramic with glue?
so i removed all the old tile on my parents bathroom wall and it is chiprock with adhesive glue left. I want to lay new ceramic on teh wall but my question is should I scrape off all the old glue when i put the the new glue on or is it ok to just put new glue on top of that old glue and lay my tile?
Also when I removed the old tile the layer off gypsum came off in some small sections and there is cement...will the glue stick to this or should I just use mortar (the white stuff for stone)it's like glue anyway.I have some of this left over from a previous job so don't have to buy it.
the tile I'm laying is ceramic 9x12's.
Limit54 is offline   Reply With Quote
Old 03-01-2010, 06:05 AM   #2
Ideally, you should have removed the old drywall and tile, which gives you a new smooth surface for the new. But chip off high spots, then skim coat with drywall compound, sand lightly. That will give you a smooth surface.
I assume you are not talking about shower walls, only walls outside the tub/shower??? Never tile over drywall, especially old drywall, in a shower/tub.
Old 03-01-2010, 10:12 PM   #3
no its not a shower wall...there isn't even a shower in the bathroom..its an on-suite, jut toilet and vanity.
Thanks.
Removing old carpet, left over glue...best way to remove it? RyanD General DIY Discussions 5 06-24-2009 04:37 PM
Any idea how to remove glue from wooden floors tash08 General DIY Discussions 5 10-29-2008 06:24 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Want to remove wall found heating/ducts wondrgirl HVAC 2 06-04-2005 10:54 AM
