Ditra Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 06:31 PM   #1
ditra floor
I just laid a ditra floor system in my bathroom, I followed directions, but I when I went in and looked the floor the next day , I noticed bumps in the floor, I used the recommended thin set and wonder if it is suppose to be this way, doesn't make sense and I worry about setting tile on this uneven surface... can anyone help ???
Jackie
jlynch is offline   Reply With Quote
Old 07-27-2009, 07:53 PM   #2
Registered User
Termite's Avatar
Moving you to the tile forum where hopefully someone can help.
I'd suggest posting pictures of what you're dealing with.
Old 07-27-2009, 10:23 PM   #3
Rewards Points: 26
I've used ditra a couple of times now and never had bumps. I usually tile mine right away though. Are these bumps solid, meaning to much thinset under them. Or are they like air bubbles where the ditra didn't stick to the thinset? Also how big are these bumps?
ponch37300 is offline   Reply With Quote
Old 07-28-2009, 08:10 AM   #4
I think it's too much thin set underneath, I guess now the question is to keep it down or tear it up. I am leaning towards tearing it up, and redoing it so that my tile lays correctly.. it's pretty bumpy and I am worried about the tile not laying right.
Old 07-28-2009, 09:10 AM   #5
Rewards Points: 26
How big are the bumps? I watched a video on the web of some guy cutting a section of ditra out and replacing it once, think on youtube. Not sure if this is acceptable or not.
I would fix the bumps by either cutting them out or just ripping the whole thing out and redo. And make sure you use the flat side of the trowel to smooth the ditra out next time. Also make sure you are using a quality thinset. good luck
Old 07-29-2009, 07:14 AM   #6
ditra floor
Poncho,
Thanks for your help, I ended up tearing up the floor and using cement board. I have both my bathrooms torn up so I needed to move quickly.. You were right it was the thin set that I used, I used way to much and could see it when I picked up the floor. Once again thanks.
Jackie
Old 07-29-2009, 08:37 AM   #7
Rewards Points: 26
glad you got it fixed. If I remember right ditra recommends a small v notch trowel that I couldn't find locally. Something like 3/16 or 5/16. You don't need much thinset under it.
What size trowel did you use for thinset under your cement board?
Old 07-29-2009, 10:41 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 412
Jackie,
Schluter recommends either a 3/16x1/4 V or a 5/16 V. I don't think the 1st leaves enough mortar so I've been cutting deeper grooves for many years. Then several years ago they came up with the 5/16 recommendation. Great, I still haven't seen one of those locally.
I'd love to know how you did this. Aside from using too much thinset, (what size trowel did you use?), you may have mixed it too thick and for sure you didn't "beat" it with a wooden float into the mortar and work the air out. You used a modified thinset right?
Jaz
Old 08-12-2009, 07:35 AM   #9
I think the problem was my thin set was too thick and I did not use the right trowel. I actually found the right size at home depot. I used the ditra left over in the new closet of my bathroom and it worked really well. I am also redoing the master bath in the next month or so and plan on using it for that bath. I liked the results once I learned how to use it properly. I agree with Poncho that u get better results when you lay the tile immediately after you lay the ditra. I really appreciate the comments it helped alot. I have just about finished this bathroom and it looks really good. I am in the process of a major reno in my new house so I am positive I will be back with questions.. Thanks..
Old 08-12-2009, 07:38 AM   #10
Yep you are correct I did not beat it properly.. I'll let you know how the next bath comes out..
Old 08-12-2009, 05:17 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I can make another suggestion also...
The folks at Schluter say you can install the DITRA and then immediately begin your tile installation.
My reccommendation is once you have the DITRA installed and smoothed and flat..."STAY THE HELL OFF OF IT OVERNIGHT FOR GODS SAKE."
I'm one of those people that thinks the customer IS NOT always right and that Schluter Techies need more time in the field if they are going to tell you how to install their products with any real conviction.
Old 08-12-2009, 07:16 PM   #12
Rewards Points: 4,748
bud, help me out,,, nagzilla's on her own w/the tile guy in hilton head
stadry is online now   Reply With Quote
Old 08-12-2009, 07:20 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is there a missing link or something? I'm not following.....
Old 08-12-2009, 08:38 PM   #14
the thread below - new tile over old - HURRY ! ! ! nagzilla's got the ckbook
nagzilla wants new bathroom flooring :-(
Old 08-13-2009, 03:40 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK I'm catchin' up......here ya go:
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
