Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 07-25-2011, 10:08 AM   #1
Diagonal cutting 16" tile
I am laying new tile for in front of my fireplace and have run into an issue. I need to diagonal cut a 16" tile, but my cutter is only 20" so it will not get the job done. I only have 4 tile that need cut, so I do not want to spend more than probably $40 for a new cutter (if that, free is better). I could get new tile, that my cutter could handle, for the entire area for less than $40. Is there a way to cut the tile by hand, or are there any other tricks?
P.S. looked into renting a tile cutter from HD, but it was $50 a day so still cheaper to just replace the tile.
turtlefan is offline   Reply With Quote
Old 07-25-2011, 12:35 PM   #2
an angle grinder will cut tile, slowly and requires a very steady hand
Techy is offline   Reply With Quote
Old 07-25-2011, 06:48 PM   #3
Tileguy
Bud Cline's Avatar
Mark the tiles for cutting and take them to a tile store or call a tile installer to cut them for you. Take them to his current job for him.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 05:02 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
