Default Heated Glass Mosaic Tile Floor Problems - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 05:43 PM   #1
Heated glass mosaic tile floor problems
Hi first time I've ever joined a chatroom. Got timed out the first time trying to ask my question. Please bare with me. Just found out after years of having 1" tile popping off our floor the the contractor (several years ago). Did not use the proper backer board for floor. I have approx. 20 tiles off right now. Have tried many products to fix Not very successful could I put a bamboo flooring over the top off the glass tile and still feel the heat? Thanks. Hope I can find the place to check for replies.
tyler13 is offline   Reply With Quote
Old 09-15-2013, 06:12 PM   #2
DIY staff
Rewards Points: 7,174
To bad about the poor tile work---Yes, you could install a floating floor over that and still get heat---you will loose some due to the foam backer---but it will work.
Glue down would be better but what sense would it make to glue something to loose tiles?
Old 09-15-2013, 08:40 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Tyler, welcome,
Although bamboo might be more moisture resistant than most hardwoods, you should not use either in a bathroom. A dry powder room fine, but not a bathroom or laundry area.
I can't tell what happening with your floor, but doubt the wrong backerboard is the problem. What did he mean by that anyway? What type of backer do you have?
A carpet guy giving ceramic tile installation advise.........sounds like trouble perhaps. Ceramic tile setters are required to be licensed in many states.
More specific info please.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
joecaption (09-15-2013)
Old 09-15-2013, 08:52 PM   #4
Bill Kearney
Rewards Points: 1,174
Yeah, tile depends more on the floor being stable than anything else. Any movement at all and you'll have things cracking or popping up. If the joists below weren't strong enough to handle the added weight then it wouldn't much matter how the tile was laid. Granted some products (Ditra) can help mitigate this but there still needs to be a decent base. Or did they really do something stupid like use the wrong material to lay the tiles?
And was the glass mosaic rated for floor use?
Some pictures would help. Especially if you can show details of the layers of what's there and where it's coming up.
wkearney99 is offline   Reply With Quote
Old 09-15-2013, 09:56 PM   #5
Thanks so much for replying. I pulled the carpet up in the threshold and have attached pictures. Unfortunately I couldn't do a side shot, but it looks like he laid the tile on the subfloor I think you can tell that from the pictures. FYI the contractor is not in business any longer and I can't find information on him. Shouldn't he used a cement board? This was at least 7 years ago. I wish I knew then what I know now. (Ha ha). I a fairly new DYIer.
Old 09-15-2013, 10:44 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
Tyler,
Since you said;
I assumed he had used a tile backer of some type. But holy cow, that looks like OSB to my eyes. Any tile fool knows you don't bond tiles direct to that. Plus you think it's "the" subfloor.
Gee......what a surprise.
OK, so either rip it up and start over, or get a slightly bigger rug every year.
Jaz
Old 09-16-2013, 05:58 AM   #7
DIY staff
Heated floor? Where are the heating coils?
Old 09-17-2013, 01:15 AM   #8
First off I don't know if the tiles were appropriate for floor use. I didn't ask the question at the time. Second. The heat is a mesh type fabric that you staple to the floor before lay the tile.
Old 09-17-2013, 09:02 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
Tyler,
Sorry, but you need to start over. This time be sure to hire a good tile setter. If you have any doubts, ask here first.
Jaz
tyler13 (09-17-2013)
Old 09-21-2013, 01:39 PM   #10
Remodeling Contractor
Pictures are unclear. But you said the floor heat was a mesh type? And then he just thin-setted 1x1 glass over that???? No underlayment of any Kind?
I don't think that 1x1 glass IS meant for a floor tile anyway, Unfortunately
you may be pulling this floor and LOOSE your floor heat system with it.
I ALWAYS use a SLU over floor heat, This way at least the floor heat system is encapsulated and protected in case the floor tiles need to be removed.
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
Need input please! (Mosaic on tile) tandj1997 Tiling, ceramics, marble 19 05-21-2011 10:53 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 09:54 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
