Deep Shower Niche, Retrofit - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 07:06 AM   #1
Rewards Points: 4,796
Deep shower niche, retrofit
I want to put a niche in a wall that has a lot of space behind it - at least 8". But they want a niche that is about 5" deep. The wall is already up and I'm going to be cutting the niche into the wall when I get the tile up to that point. (The wall is already up and covered with Kerdi.)
Normally this isn't hard, because you build a 3 1/2" deep niche using the wall behind in the stud bay. But in this case, I have to put in the back wall of the niche myself. So, suggestions for putting the studs in there for the niche, and then also attaching a back wall to those studs as the niche back?
jeffnc is offline   Reply With Quote
Shower Niche help... fatboy1729 Tiling, ceramics, marble 4 03-12-2013 07:14 AM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
