Decided To Remove Grout And Re-do - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 11:21 AM   #1
PatrickGSR94's Avatar
Rewards Points: 87
Decided to remove grout and re-do
Well I have decided to remove the grout installed Sunday night in my kitchen and redo everything with a lighter grout color. What's the best way to remove it? I have a small hand grout saw that I used to knock down any thinset in between the tiles, but that seems like it would get very tedious using that to remove all this grout (70 s.f. worth of 12x12 tile, 3/16" joints). I have an angle grinder with a masonry disc that's about 1/8" thick, might that work better? I also have an older Dremel rotary tool but probably don't have the exact proper tool attachment for grout removal. Suggestions?
Also wondering what grout brand I should go with. I used this Mapei Keracolor S from the "blue" store, and then afterwards read of many people having problems with uneven finish color with this brand. I can also get Polyblend from the "orange" store. I have used Laticrete 1500 sanded grout before with good success, but that is not sold locally anymore other than one single specialty tile store. Should I go with one of those or look at other specialty tile stores in the area to see what they have?
PatrickGSR94 is offline   Reply With Quote
Old 03-15-2011, 01:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Please tell me this isn't efflorescence
XXX
Old 03-22-2012, 10:38 AM   #3
polyblend
Do not use polyblend around tub it does not hold up to water and will come off....had idiot contractor use it and now i have to do the repaire.
ngalgan is offline   Reply With Quote
Old 03-22-2012, 11:12 AM   #4
Rewards Points: 14,026
Please do not even try a 4-1/2 grinder, a sure way to distroy the tile.
I use my Rockwell multi crafter and a diamond blade. Total control and goes fast.
Old 11-25-2016, 11:13 AM   #5
Rewards Points: 87
Re: Decided to remove grout and re-do
Well it's been awhile since I've been here last, and that last post was about a year after I finished the kitchen floor. I did end up using the grinder with a diamond blade disc after cursing over a little hand grout removal tool for far too long. I made quick work of the grout, but the dust was insane. We tried to use plastic to cordon off the area, but dust still infiltrated literally everything in the area. We had to throw out a bunch of food in our pantry because the dust got into all the containers.
Anyway, it's been nearly 6 years now since we put in the replacement grout, and for the most part it's holding up fine. Only problem is that I never got around to sealing all the grout, and some of it has gotten a little dirty. Oops. The part that I did seal still looks great!
Old 11-25-2016, 11:39 AM   #6
Rewards Points: 3,742
This is what you should have used to remove the grout.
http://www.harborfreight.com/variabl...ool-63111.html
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
JazMan (11-25-2016)
Old 11-25-2016, 12:09 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 412
No way to seal off the area from dust. Dust will also get into other rooms of the house by HVAC and even wind. As you now know an angle grinder is the wrong tool.
Jaz
Old 11-25-2016, 07:38 PM   #8
Rewards Points: 87
That tool would have taken a million years. Angle grinder was the right tool for my situation, as it made quick work of the job (15-20 minutes). It was dusty but we dealt with it. HVAC was off, and the air returns were sealed. I was glad to be done with it. That was nearly 6 years ago anyway, so it doesn't really matter now.
remove grout from Allure vinyl flooring abkjr Flooring 2 08-02-2010 06:21 PM
Remove tile grout ninghai Flooring 6 06-06-2010 09:51 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 08:54 PM
haze on grout... remove? fabian Flooring 4 02-27-2009 07:59 AM
Remove Old Grout colesmommy Flooring 4 06-30-2006 08:27 AM
