Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-14-2008, 10:28 PM   #1
Lost in Space
Default Cutting Unusual Backsplash Tiles
Greetings Everyone,
My Buddy came over yesterday all excited about the new tiles he purchased for his Kitchen Backsplash. They were a special order and he paid a crazy amount of $$$ for them. Since this is my best friend I'm on point to install these for him.
I have done quite a few backsplashes but never with this kind of tile. I am at a loss of how to cut them. Here are the specifics:
1" x 2" Stainless Steel tiles
Brick pattern on a 12 x 12 sheet
They look like a small ceramic tile with a Stainless steel "capping" on them. (Not my taste but I cant seem them from my house so ....)
How should I cut these tiles? I dont know if the wet saw can handle the Stainless Steel part of the tile? I would need to cut these at the begining and end of the run and around the outlets.
I was thinking a Dremel with a metal blade or maybe a grinder, problem is that the tile is so small it would be hard to manage the material with a grinder? In addition I have to be concerend with scratching them since they are stainless steel.
ANY ideas or suggestions would be greatly appreciated...
Thanks once again!
Tool Junkie
Tool Junkie is offline   Reply With Quote
Old 12-15-2008, 08:11 AM   #2
may get different ideas but i'm for 4" .110 diamond blades,,, just saved the bride's backsplash freehanding the cut w/4" grinder,,, same for tile replacement on the hall floor,,, for metal tile, i'd be using the tabletop tile saw & cut wet,,, if i owned a dremel, wouldda tried that 1st.
roger on the ' can't see 'em from my house '
yesitsconcrete is offline   Reply With Quote
Old 12-15-2008, 01:56 PM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Honestly, it really makes a difference on what the manufacturer says. I will be doing a copper backsplash in the upcoming months. I did quite a bit of research on metal covered tiles. Some manufacturers tell you to use a carbide saw blade, others state a metal cutting wheel on a grinder and still others say it's ok to use a wet tile saw. I can foresee issues using any of the above. If you are dry cutting the metal, once you hit the ceramic it will become a dusty mess and you might start chipping the tile. Same goes with a grinder. Of course, using either tool with a 1x2 mosaic tile means you need to be super careful you end with as many fingers as you started with. Finally, using the wet saw, I'd imagine you'd chew up the blade some. This is what I'm going to be dealing with and I'll be using a wet saw with a "disposable" blade.
Oh yeah, make sure you file the metal edging after cutting too. Otherwise, it could be a bloody mess the first time someone goes to clean the backsplash!
Angus
My Albums
angus242 is offline   Reply With Quote
Old 12-15-2008, 02:29 PM   #4
didn't think about that part & angus' right,,, there are blades for just about anything 'cuttable',,, that doesn't mean you can find 'em at the apron stores, tho,,, i'm not a fan of carbide when diamonds're avail.
ps - all blades're disposable
Old 12-15-2008, 02:36 PM   #5
angus242's Avatar
True...although I will NOT be using one of my $70 porcelain cutting blades for that job. I'm thinking a quick trip to Menards and see what tool shop diamond blade is available for $25.
Angus
My Albums
Old 12-15-2008, 07:39 PM   #6
Tileguy
A tile wet saw will cut the stainless steel tiles that are clad over a backerboard material. Go slow don't get too aggressive.
If the tiles are hollow your best bet is a ban saw using a fine steel blade 18 teeth per inch or more.
An abrasive metal blade can also be used but it will tarnish the steel with no way to really recover from the damage.
Or, you can arrange your layout so that none of the steel tiles must be cut.
With copper tiles a very firm grip is required while cutting. The copper will cause the blade to drag and can snatch small tiles from your grasp.
In any case if the tiles have a protective cover over them, leave it there as long as possible to protect the surface of the tile.
Old 12-16-2008, 08:53 AM   #7
Lost in Space
Thanks Bud and everyone else for thier input. Not cutting the tiles is not an option since it is a running bond brick pattern .
I think I will try the wet saw with a backup plan using the dremel or grinder, dont have a band saw so that is not an option.
Much appreciation to all for thier good advice!
Old 12-16-2008, 09:28 AM   #8
we use a fair amt of .110, .250, .375, & .500 4" blades along w/.500 & .375 v-shaped crack chasing blades along w/turbo 12 & 24segment cup wheels,,, best place i've found's a guy on ebay - fc727 - pay him & you've got it 3 days later,,, NO FINANCIAL INTEREST IN HIS SUCCESS OR FAILURE - NONE ! ! !
More On This Topic
Hi, this is Brian Carter on behalf of Expertvillage.com. I have 10 years of ceramic tile installation experience. Today I am going to show you how to make a right angle cut. What I would like to do is I would like to have two lines, one the full length... Read More »
I showed the toilet cut; that is where you are coming around the flange of the toilet. What we showed here was that you could kind of rough it in. Maybe you cut a few pieces in with the larger saw and then with the grinder fitted with the dry blade and... Read More »
Hi, this is Brian Carter on behalf of Expertvillage.com. I have 10 years of ceramic tile installation experience. Today I am going to show you how to make a three-sided cut using the grinder fit with the ceramic tile dry blade. Okay so we are going to do... Read More »
Hi, My name is Brian Carter on behalf of Expertvillage.com. I have ten years of tile experience. Today I am going to show you what tools you are going to need to cut ceramic tile. First we have a ceramic tile wet saw, this is the large tool here, we are... Read More »
How to Cut Tile
How to Cut Tile by Expert Village
I’m Lee; I have a degree in architecture, about ten years experience in the construction field, and we are laying a diagonal countertop today. And we have to go out and get ourselves a wet saw. A wet saw is just- it just means that the blade is... Read More »
[IMG] code is Off
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
calking backer board to tub glassman General Discussion 13 06-19-2008 10:41 PM
Cutting installed tiles steve65 Flooring 5 01-29-2008 03:27 PM
Ceiling Tiles - cutting recessed ones? Stargazer Building & Construction 3 12-04-2007 11:55 AM
Tin 18x18 tile's for backsplash.... dcd22 Remodeling 1 10-09-2007 06:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
