Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-23-2009, 09:00 PM   #16
Serious Do It Myselfer
WOW - I take it you were plunge cutting those bad boys.
I agree with your assumption about money vs quality. Nowdays it seems like the best advertisers are the winners - quality takes a back seat.
Thanks for getting back.
Jim
Jim W is offline   Reply With Quote
Old 06-24-2009, 03:29 AM   #17
Why don't you get rectangular tile instead of going through all that trouble. Maybe hire someone to do the job for you.
Dana11 is offline   Reply With Quote
Old 06-24-2009, 10:26 AM   #18
yummy mummy's Avatar
.......hiring someone?
.......no satisfaction in that.......
yummy mummy is offline   Reply With Quote
Old 06-24-2009, 02:48 PM   #19
toocheaptohire's Avatar
um....this is a DIY site, right?
toocheaptohire is offline   Reply With Quote
More On This Topic
About Nail Gun Nails
About Nail Gun Nails by Expert Village
This is Rob McManhon for Expert Village. There are different types of gun nails that you use. These are for framing. They are 3 ¼ inches - it is 12 pending nail. These are more for siding or using thinner stock that it. 8 penny - 2 ¼ inches... Read More »
This is Rob McManhon for Expert Village. If you are using narrower stock - this is ¾ and an inch thick, you want to use your narrower nails. Now this is the type of material that you would use for doing trim. Now you would put it over your rough... Read More »
Hi! This is Elizabeth, and on behalf of Expert Village, we’re moving forward with creating a shaker card as part of our series of using beads in your cards. So what we’re doing is we’ve cut the window in the card. Now, we’re going... Read More »
Pinning with a Nail Gun
Pinning with a Nail Gun by Expert Village
This is Rob McManhon for Expert Village. One method that is good to know with a framing nailer is pinning. This is something that you would use if you were building a header for example. Now a header generally for 2x4 wall would be whatever the... Read More »
This is Rob McManhon for Expert Village. The other thing that could happen is that you can get a jam. When you get a jam you'll find that the pin will be stuck down all the way at the end here, and usually you can just take any long piece of metal and... Read More »
[IMG] code is Off
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 02:33 AM
Cutting installed tile simonb Flooring 9 06-23-2008 01:04 PM
Cutting Porcelian Tile without chips BruceStone Building & Construction 3 02-01-2008 06:33 PM
Cutting Tile rookie1 Remodeling 9 10-22-2007 06:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
