Cutting Mosaic - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 11:09 PM   #1
Rewards Points: 4,796
Cutting mosaic
When cutting mosaic with a glued mesh backing on a wet saw, it seems the water is always loosening the glue and after a time the tile starts falling apart. This is very frustrating for me. Does anyone know if this only happens with a certain mesh, or a certain type of adhesive? Do others experience this, and if so have you found a solution? I've never heard this mentioned in a book or forum, yet it's a real production killer for me at times. If I immediately place the cut tile on a towel and rush it to position, it helps, but otherwise it often turns into a mess.
jeffnc is offline   Reply With Quote
Old 09-11-2013, 09:58 AM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
If your using sheets of mosaic, why not cut the mesh and tile snips your cuts?....
JetSwet is offline   Reply With Quote
Old 09-11-2013, 10:55 AM   #3
DIY staff
Rewards Points: 7,174
That is a huge pain---some tiles are worse than others---
This helps----place the sheet to be cut on a dry scrap of tile---cover the sheet with a sheet of card board or wax paper to keep as much spray off of the sheet as possible---then cut.
I have learned many new curse words because of this problem----idiot design---
Old 09-11-2013, 01:46 PM   #4
Tile snips or other cutters won't give nearly enough precision or clean cuts for complicated mosaics, or cutouts for outlets, cutting tiny pieces of mosaic, glass, etc etc.
Old 09-11-2013, 09:13 PM   #5
angle grinder with a diamond wheel works great. might be a little dusty but your tile won't come loose from the backing.
Old 09-11-2013, 11:31 PM   #6
Yeah I'm sure that would work. Just not as precise with the more complicated mosaics as the saw, but might be the way to go....
Tile backsplash with marble and glass mosaic ponch37300 Tiling, ceramics, marble 13 05-02-2013 08:38 AM
Glass Mosaic tile Question, cutting and grooved trowel ryan5068 Tiling, ceramics, marble 3 11-20-2011 10:33 AM
Cutting Glass Mosaic Tiles? dukester544600 Flooring 2 04-19-2011 02:43 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 04:02 PM
