Cutting Ceramic Tile Away From Bathtub - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 08:29 PM   #1
Cutting ceramic tile away from bathtub
I am remodeling and don't want to remove tub. My problem is that I am going to put new tile on the tub surround and I need an effective way to cut the tile near the tub edges without destroying the finish on the edges. The tile is currently laid under the tub lip. I plan to put new tile up to the lip after removing all of the current tile. What is the best tool to use. A grinder with a ceramic tile wheel? Could be hard to control etc.
Suggestions.
Tomgrillo is offline   Reply With Quote
Old 03-23-2011, 08:37 PM   #2
Rewards Points: 558
pictures would be nice...
epson is offline   Reply With Quote
Old 03-24-2011, 12:04 AM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Tom,
are you talking about a soaking or whirlpool tub mounted on a wooden deck? If the tub is mounted on top of the tile like you describe, I would consider disconnecting the plumbing and raise the tub up, or take it out completely and remove the tile. As long as the tub wasn't set in a bed of mortar, it should come out easy enough with a couple of people. Pictures would help.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Preparing stud tubwalls for ceramic tile Tudy Kitchen & Bath Remodeling 7 07-09-2010 06:13 AM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 09:11 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Ceramic tile in bathroom ClnlBrahm Remodeling 11 09-21-2008 10:09 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 11:37 PM
