cutting 12x12 tile
Because the grout sits lower than the face of the tile, and you don't want to cut people's feet with hard corners and edges.
I guess you could try having the grout level with the face of your cut tiles, but there are two problems. One is that the normal tools you use to put in grout push it down, since the normal goal is to have it slightly recessed. Second is that you're going to have to trim off the four beveled outside edges of each tile you start with so that those edges are as high as the ones you cut. This is going to mean even more material lost than you were initially having a problem with.
That said, there are all kinds of different tiles out there. Some might not be beveled.
Jack Olsen
