Cut Tiles At Door Threshold, How To Finish? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 11:42 PM   #1
PatrickGSR94's Avatar
Rewards Points: 87
Cut tiles at door threshold, how to finish?
I'm laying tiles diagonally in my kitchen, so I will have cut tiles at all edges, including along one exterior door with a threshold. This threshold is the metal type that comes in most prehung exterior metal doors, with a plastic edge along the interior side. The cut tiles will run adjacent to this plastic edge. How would you finish this? Use grout color-matched caulk, glue a piece of base shoe to the threshold to cover the tile edge, or both? Or something else?
PatrickGSR94 is offline   Reply With Quote
Old 03-10-2011, 06:30 AM   #2
DIY staff
Rewards Points: 7,174
If you make good,clean 'show' cuts---then a flexible caulk will do.
The cuts could be covered with a small trim--But securely attaching that can be a challenge
You have metal and ceramic---hard to nail---clean cuts and caulk are the first choice.--Mike--
Old 03-10-2011, 08:24 AM   #3
Rewards Points: 87
Well the edge adjacent to the tile (the edge underneath the actual door panel) is plastic. And the tile is porcelain.
Old 03-10-2011, 12:09 PM   #4
DIY staff
Porcelain is a ceramic--just the most water resistant----Still I prefer the look of a 'show' cut with caulk over the trim----It's a look---your choice.
Old 03-10-2011, 12:18 PM   #5
Rewards Points: 249
This might go without saying, however if you're looking to make good cuts against the threshold or any contoured lines, get one of these :
http://www.plumbersurplus.com/images/prod/1/43836.jpg
And I agree, use a good grout and cover w/ trim if wanted, but if the cuts are good its not a necessity.
Durt Ferguson is offline   Reply With Quote
Old 03-10-2011, 08:23 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't want to grout that juncture. You should use caulk there. Grout will not last.
XXX
Old 03-11-2011, 07:14 AM   #7
Rewards Points: 249
Good catch
Old 03-13-2011, 07:44 PM   #8
Rewards Points: 87
Well I could not seem to get an even, consistent gap along the threshold so I'm just going to glue a piece of shoe mold to the threshold.
Old 03-13-2011, 11:46 PM   #9
Master of none
How are you cutting the tile?
Why can't you get a consistent gap? What are you using to cut the tile? What adhesive are you using to attach the shoe moulding to the metal threshold?
handy andy is offline   Reply With Quote
Old 03-14-2011, 12:32 AM   #10
Rewards Points: 87
I'm not attaching it to metal. The part of the threshold underneath the door panel (adjacent to the tile) is plastic. The sloped portion of the threshold outside the door panel is metal (standard metal-clad prehung exterior door with brickmold trim and threshold).
I was using a big MK-101 rental tile saw to make the cuts (absolutely awesome saw BTW) but my whole layout ended up slightly out of square, and I couldn't get totally accurate marks with my china marker pencil. The layout is a diagonal jack-on-jack so it being out of square really isn't visible at all. I'm sure the walls aren't square, either.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
