Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-25-2011, 03:12 PM   #1
Custom Shower, Soap/Shampoo Niche
I am doing a custom shower. I want to make a niche to place soap/shampoo etc. I typically see small shallow ones like this:
http://www.shower-stalls.com/marble-424.jpg
I assume to fit in the stud bay. However, I have a large void behind the wall, so I want to take advantage of the space. So I wanted to have a rather deep niche (~1ft), as well as wider and taller, and maybe tile shelves into it. Is that a good idea? I've been told that its not because the larger surface will be more prone to leaking.
Also, what is the proper way to frame a typical niche?
acerunner is offline   Reply With Quote
Old 02-28-2011, 08:29 PM   #2
See here:
http://www.danielskitchenbath.com/Sh...er%20dish.html
drevil is offline   Reply With Quote
Old 02-28-2011, 08:44 PM   #3
Tileguy
Bud Cline's Avatar
You can build any size niche you wish. Frame it with 2X4, slope the bottom 2X for drainage, clad it with cement board, caulk the seams then waterproof it with liquid waterproofing. Easy to do, not a big deal.
There are also many pre-made niches but they are all made to fit in a stud-bay. So if it is custom you want, build it yourself.
Old 03-01-2011, 07:05 AM   #4
Buying the first round
LIHR's Avatar
There's nothing like a custom shelf to set your shower apart from those pre-fabs.
As stated above, follow the waterproofing steps, and I like switching up the rear niche tile with a different tile and having my natural stone fabricator cut me custom shelves from a huge choice of remnant left overs laying around the shop.
http://www.ranteso.com/
LIHR is offline   Reply With Quote
building custom shower base wombosi Flooring 3 06-17-2010 09:54 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Custom Shower Curb nelsonc2121 Tiling, ceramics, marble 23 02-10-2010 05:43 PM
Custom Shower Project - need advice CK4500 Project Showcase 24 01-28-2009 12:59 AM
Custom Shower addition plumbing questions alxv Plumbing 1 10-09-2008 03:34 PM
