Crown Moulding In A Shower Stall? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 02:39 PM   #1
Rewards Points: 99
crown moulding in a shower stall?
I'm doing a new bathroom, with 9' ceilings. I'm planning on running crown moulding around the top, and this ideally will extend over the shower stall. the stall glass/door etc will not go all the way to the top, but I'm planning on having the tile go all the way up. how do i think about the crown? I've seen exa,plea where the crown sits right on top of the tile? any suggestions would be welcome! thx jp
yellowkid is offline   Reply With Quote
Old 07-28-2014, 02:54 PM   #2
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Won't the tile stand proud of the wall? Are you going to notch the crown or what is your plan to deal with the difference in thickness?
I put crown up in our bathroom to cover the seam around the "tin" ceiling. I used the foam stuff and got the square corner things so that I only had to do straight cuts. It looks good and really finishes the room nicely.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 07-28-2014, 04:28 PM   #3
Rewards Points: 99
your absolutely right about the tile standing proud -- one of my concerns! and notching the crown would look bad I think. I don't want to stop the tile significantly below the ceiling with a gap of wall as I think that would look a bit cheap, but I could stop the tile just below the crown so they abut or the crown sits on top of it. not really sure whats the best.
Old 07-28-2014, 06:40 PM   #4
DIY staff
Rewards Points: 7,174
You can step the crown out as you go from the wall to the tile---that will be a thin bit of miter--but you can do it---
You could also add a wood strip behind the crown that is the same thickness as the tile---
Old 07-28-2014, 08:44 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's the way to do it...shim the crown molding out 1/4" so as not to lose the appearance of the crown molding profile. I use standard lattice material for the shims top and bottom of the molding.
XXX
Old 07-28-2014, 09:57 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
You could step it out like Mike said, like we did in our kitchen. One thing I would do is put some wood backing above the tile to fasten the molding to.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (07-29-2014)
Old 07-31-2014, 02:16 PM   #7
Rewards Points: 99
guys thx very much -- very helpful. i like the idea of shimming and a small miter will look seamless. and jim thx for the illustration. beautiful work.
The Following User Says Thank You to yellowkid For This Useful Post:
BigJim (07-31-2014)
crown moulding paint color doyelc Painting 8 07-14-2012 06:22 PM
area surrounding top of shower stall mustangsalee613 Kitchen & Bath Remodeling 1 03-20-2011 11:08 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 10:00 AM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 03:41 PM
Stall Shower Renovation Rick Bruner General DIY Discussions 11 01-20-2008 07:34 PM
