Cracked Tiles - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 11:44 PM   #16
Rewards Points: 150
Closeup of the "extra" grout.
klmeenan is offline   Reply With Quote
Old 06-26-2011, 05:57 AM   #17
DIY staff
Rewards Points: 7,174
Yuck---Those are some small grout lines---lots if work. What have you found to be the best tool?
I recently bought a Harbor Freight multi-tool----fastest thing for grout removal----I have a diamond blade for hard grout---but I found that a standard round blade works quickly on softer grout.
Worth checking out----their blades are about 1/2 the price of the fancy brands and several blades came with the unit I purchased.
This can make an ugly job a bit more tolerable.---Mike---
Old 06-26-2011, 08:17 AM   #18
Rewards Points: 150
My in-laws bought my husband a Rockwell soni-crafter for Christmas which came with several blades. I had to go buy a thiner blade to remove the grout.
I have found that our local lowes sells the blades but not the size I needed so I got an adaptor piece to be able to use dremel blades since they have a 1/16 one diamond one. Where the tile is even smaller I am using the blades that are meant for cutting wood.
I have to admit I love it. Where the grout isn't patchy looking, it cuts through like butter. I have trimmed some vinyl flooring at my moms and also cut some door trim higher so I could slide the flooring under it. It was also handy when I needed to cut a piece of 2x4 wood. My brother has borrowed our mitre saw and I hate handsaws. It took a lot longer than using my mitre but it was faster than the handsaws.
The photo shows 75% of the tile I am regrouting. The rest is the "throne" room and the shower. I can't get it in one picture. I can't imagine doing all this by hand.
tiling over cracked tiles bobgold Flooring 3 02-12-2011 07:54 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 08:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
