Cracked Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 01:27 PM   #1
Rewards Points: 150
cracked tiles
We purchased out house in 2002. Within the first year one tile on the platform around our tub cracked. They repaired with since it hadnt been over a year. It has happened again. I have chipped out the tile and I can see that the tile is over where 2 pieces of wood (not sure what kind) almost meet. The wood that the tile on the front of the platform is on also doesnt quite meet.
I think the tile cracked due to movement of the wood. How can I fix this without tearing everything up?
klmeenan is offline   Reply With Quote
Old 05-26-2011, 01:56 PM   #2
DIY staff
Rewards Points: 7,174
That's a 'builders special' tile job. No backer--no isolation membrane---nothing.
Sorry there is no way to fix that right.
Jeez I hate to be the first to tell you that. Reset the tile with flex set thin set after you add a few screws to hold the wood---pray---sorry,Mike--
Old 05-26-2011, 03:33 PM   #3
Rewards Points: 150
I figured we were screwed when I took the tile off. I am also re-grouting as well. I need to make do for 2 years then I can yank it out and do it right.
I talked with someone who told me that the tilers do track jobs and don't care. So I'm totally not surprised.
Old 05-26-2011, 06:08 PM   #4
Rewards Points: 150
Sorry these particular tilers. I don't want anyone to think I was saying all tilers.
Old 05-26-2011, 06:17 PM   #5
DIY staff
I just retiled one like that---pounding with my fist knocked most of it loose--a painters tool got the rest.
Some builders should be hanged.(hung) oh,than goodness for spell check.
Believe it or not clear silicone caulk is a fine adhesive and will offer a flexible buffer to that wood--
If Bud sees this he will have an opinion--This is a situation where flexible is good,--Mike---
Old 05-26-2011, 07:39 PM   #6
Rewards Points: 150
I respect both of your opinions. Bud will be right as he will tell me to redo it the right way. I will do it the right way in 2 years. I am in the middle of fixing the drainage issue which has my backyard as a swamp for most of the spring.
I really don't want to put anything on my charge card if I don't have to. If this was my shower i would be tearing it out already. This is the bathtub which is barely used.
I think the silicone idea is genius! I'm going to do that. What do you think about doing silicone as grout around that one tile? Thanks!!
Old 05-26-2011, 07:59 PM   #7
DIY staff
It would work if you used white---a secret to neat silicone work----
Silicone will stick to any dry surface---it will not stick to a wet soapy surface---
apply your silicone --making sure that there are no voids---then spray the surface with 409 or Greased Lightning----wipe the excess silicone with your finger ---any extra will not smear onto the face of the tile.---Mike---
Old 05-26-2011, 09:34 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is there any support under that seam in the plywood? Doesn't appear to be looking from here. I think I would first use some PL adhesive in an effort to join the two plywoods together, then I would agree a good "stop-gap" temporary repair would be to use 100% silicone as suggested.
But...no more than two years then you have to take it all out and do it the right way - the clock is ticking. Promise?
By the way...that is also the wrong mesh tape that was used tere.
XXX
Old 05-26-2011, 10:08 PM   #9
Rewards Points: 150
I promise! Redoing all the tile in the bathroom is going to be a huge job since it's all over the place. We have to get rid of the water in our backyard. I'm tired of walking through muck when we have to mow. Now that 3/4 of our trees are gone due to snow the last 2 years it's time to deal with the drainage that the builders refused to deal with back in 2002.
I am already making my husband look at tile knowing it's going to take a year to work out a compromise on what we will install.
Thanks for all the wonderful advice. You and Mike are the best!
Old 05-27-2011, 07:21 PM   #10
Rewards Points: 150
Pl adhesive? Which one?
Old 05-27-2011, 07:49 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Pl adhesive?
"PL" adhesive is a premiere construction adhesive, basically the same as Liquid Nails but in my opinion a better product. The label will say PL-200, or PL-400 or something like that. Try to force some in the crack between the two plywood's then smear some on top of the plywood bridging the crack. After that dries...tile it using 100% silicone.
XXX
Old 05-27-2011, 07:53 PM   #12
Rewards Points: 150
Yay. I got pl 400 since it said subfloor and deck. Thanks!!
Old 05-27-2011, 07:59 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dat'l work!
XXX
Old 06-26-2011, 12:40 AM   #14
Rewards Points: 150
Bud & Mike - thank you so much for helping! My husband and I are currently debating on what tile we will use to replace everything. We have yo discuss it now as it will take us forever to agree on something.
While fixing the tile, I have decided to completely regrout the entire bathroom (and eventually the other bathrooms too). We have a lot of spaces where the grout seems to have just disappeared. Other areas where the grout feels smooth (unsanded and still white) and others that feel rough (sanded and off white) and easily stain.
I spoke with a neighbor who is having a similar issue. She called someone to get an estimate to fix her grout. She was told that the tile guys grouted and then someone else did a second coat but used thinset instead of grout.
Could this be what is causing the gaps and discoloration of the grout lines? This might explain why some of the grout comes out white, Powderly and easily while other areas is grainy, kinda funky colored and takes longer to get it out.
Thanks for all of your help! As much as I would love to retile this now, our house funds were well spent on our drainage issues. Last 4 storms our back and side yards didn't turn into swamps!
Old 06-26-2011, 12:42 AM   #15
Rewards Points: 150
Oops forgot pictures! First one is a gap. Second one is hard to see but there is a small piece of grout that isn't the same as the rest. I will try for a better picture in the am.
tiling over cracked tiles bobgold Flooring 3 02-12-2011 08:54 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
