Corner Prefab Shower & Tiled Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 08:10 PM   #1
Corner prefab shower & tiled floor
Please help!!!
We have and argument how to put the shower base in . On top of the tiled floor or before, just on the basement conrate floor?
Amy
pengu1@quickclic.net is offline   Reply With Quote
Old 10-10-2008, 11:08 PM   #2
Tile Setter
It doesn't make a difference either way.
For those curved fiberglass shower bases, it is nice to tile the floor first and save myself the pain of having to make those precise curved cuts in the tile. However, if the base doesn't sit flush on the tile, you might have some unsightly gaps that will need caulked.
If the base is straight or rectangular or surrounded by 3 walls, then it is easy to tile tight up to it.
As far as what is proper... I don't think there is one over the other.
- Bob
Tileworks is offline   Reply With Quote
Old 10-13-2008, 10:15 PM   #3
Tile and Paint contractor
I don't like those fiberglass pans.
After awhile they're a pain to keep clean.
I much prefer constructing a mud shower pan for tile installation.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 10-14-2008, 05:10 PM   #4
for the smothest look I recomend tiling first.So long as your shower drain will allow it..Take into consideration the height of the tile and the pan.The drain pipe will need to be long enough.a 12 x 12 tile usually is 3/8 to a good 1/2 thick add in the 1/2 inch of mortar for laying the tiles..you wil end with aprox 3/4 to 1 inch for a 12 x 12 tile alone.
tfb4me is offline   Reply With Quote
Old 11-09-2008, 02:28 AM   #5
the base goes on top (if that's what you're talking about)
detroitMi is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 11:12 AM
Who makes a good corner shower??? murray59 Plumbing 3 06-03-2008 02:26 PM
Shower floor base project man General DIY Discussions 2 02-23-2008 07:35 PM
How Do I Repair an Improperly Installed Shower Floor MartinGale Flooring 3 11-26-2007 08:36 PM
