Corner Bead - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 10:37 AM   #1
wraiththe's Avatar
Rewards Points: 97
Corner bead
Hi,
I purposely left extra wall space at the end of the tile here, but It looks like i came up 1/4" short. I plan on using sheetrock paper faced metal corner beads. Hoping the tile will stick to it once it is adhered to the wall. Any suggestions? Note the black wall the tile is on is cementous Wedi board, but the purple gypsum board is the other side of the corner...
I figure maybe I can use the sikaflex (used to cover fasteners on the wedi) to stik the corner bead to the wedi, and then use the joint compound on the other side. then just thinset over it.?
wraiththe is offline   Reply With Quote
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
Metal corner bead question Firehawk734 Drywall & Plaster 15 06-12-2011 02:49 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
