Concrete With Mastic: Prep For Ceramic Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-01-2013, 06:32 PM   #1
Rewards Points: 27
Concrete with mastic: prep for Ceramic tile
Small bathroom floor, formerly covered in asbestos tile. By the time I got the house the tile was already removed and they had peel and stick vinyl down, but didn't get the black mastic off before doing so.
Please note: I have already had an asbestos abatement contractor take samples of the mastic and submit them to the lab for testing- the mastic does NOT contain asbestos.
I want to know how the presence of this residual mastic ( still very tacky in many areas) will affect my concrete prep. I don't have any big cracks to fill and only one corner that is slightly out of level. If I thinset over the concrete (assuming it is cleaned of debris) with the mastic still there, will it compromise the adhesion?
If you think it needs to be removed- how? Or can it be covered over with SLC?
All advice appreciated.
Concrete with mastic: prep for Ceramic tile-image-112722014.jpg
GerardW is offline   Reply With Quote
Old 11-01-2013, 10:56 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
Gerald,
Most thin set manufacturers tell you; Adhesive residue must be wet scraped to the finished surface of the concrete, leaving only the transparent staining from the glue. To determine desirable results, do a test bond area before starting.
Read the data sheets of a few products that are available to you.
The one corner that is not flat is one too many, fix it. SLC is another option.
The scraper is a wallpaper scraper with a razor blade.
Jaz
Concrete with mastic: prep for Ceramic tile-scraper-.jpg
tile on concrete block Master Brian Concrete, Stone & Masonry 3 05-22-2013 10:49 PM
Problem with concrete floor prep for ceramic tile install tdon7 Flooring 8 11-30-2011 11:12 PM
Asbestos tile and mastic phillyDIYER Flooring 14 08-21-2011 02:46 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 10:39 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
