Coloring/staining Tired Marble Floor - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 03:37 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you aren't going for a high-polish then you may get away with dry sanding. Wet sanding may be preferable but that creates a whole new set of hassles.
Does anything go down after the sealer?
There is more than one way to do it but I always use a sealer and finish combination, two different products. The sealer should last forever and the finish is considered a sacrificial coating and can be renewed from time to time. The products I use are for commercial installations. I can send you the product names to see if they are available in your neck of the woods.
Do we know what part of the country you are in?
Old 12-11-2011, 01:12 PM   #17
Thanks that would be great!
Ibiza, the Balearic Islands. Spain
I take it there are matt finishers?
There is a so called marble guru on the island who does most of the instalations on the island!
I'll invite him over to give me a quote and pick his brains a bit. :-)
smileibiza is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Fixing sealer on polished marble floor tile fatalvipe Flooring 1 01-22-2011 02:00 PM
My Hardwood Floor Refinishing project roxksears General DIY Discussions 3 11-13-2009 05:43 PM
Noise, hollow, movement on cultured marble floor...need help? handfix2008 General DIY Discussions 8 11-04-2008 08:25 PM
existing marble floor installation Fog80 Flooring 5 04-28-2007 07:45 PM
