Cleaning Up Epoxy Grout - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 06:27 PM   #1
Rewards Points: 151
cleaning up epoxy grout
Hi. I just had my tile floor and shower installed. They grouted today using CEG Lite. After they left (just a bit ago) I noticed that they missed a bit of the epoxy haze in different areas. What is the best way to remove it (or is some residual haze to be expected?)?
Thanks,
Bob
Bob... is offline   Reply With Quote
Old 04-09-2013, 06:33 PM   #2
Rewards Points: 744
I didn't lookup CEG's instructions, but Laticrete's says, "
For persistent grout film/haze (within 24 hours), scrub area with a mixture of two gallons water and 4 oz white vinegar. Conduct a test area to verify results on polished stones.
Unlike cement grout haze that can be buffed off the following day, LATICRETE SpectraLOCK PRO Premium Grout film/haze that is allowed to cure on the tile surface may be difficult to remove."
http://www.laticrete.com/Portals/0/pdf/DS-681.5.pdf
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Bob... (04-09-2013)
Old 04-09-2013, 07:57 PM   #3
Rewards Points: 151
Since it wasn't in the CEG Lite pdf file, I decided to call tech support. They said any paint solvent. I used denatured alcohol (did try vinegar and a few other things as well).
Seemed to do the job. Thanks for your help.
Old 04-09-2013, 09:16 PM   #4
Rewards Points: 12,802
And why did you not call the people that did the job and let them clean up the mess?
Tile grout cleaning and sealing Rats Flooring 3 02-18-2013 07:35 PM
Anybody familiar with epoxy grout? MyGoldenRocks Tiling, ceramics, marble 5 03-06-2011 04:26 AM
Epoxy Grout? Suggestions Branden Flooring 4 08-10-2010 06:48 AM
epoxy grout on glass tiles? zootjeff Tiling, ceramics, marble 1 07-04-2010 08:21 AM
