-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   cleaning up epoxy grout (http://www.diychatroom.com/f84/cleaning-up-epoxy-grout-176695/)
Bob... 04-09-2013 05:27 PM
Hi. I just had my tile floor and shower installed. They grouted today using CEG Lite. After they left (just a bit ago) I noticed that they missed a bit of the epoxy haze in different areas. What is the best way to remove it (or is some residual haze to be expected?)?
Thanks,
Bob
Seattle2k 04-09-2013 05:33 PM
I didn't lookup CEG's instructions, but Laticrete's says, "
For persistent grout film/haze (within 24 hours), scrub area with a mixture of two gallons water and 4 oz white vinegar. Conduct a test area to verify results on polished stones.
Unlike cement grout haze that can be buffed off the following day, LATICRETE SpectraLOCK PRO Premium Grout film/haze that is allowed to cure on the tile surface may be difficult to remove."
http://www.laticrete.com/Portals/0/pdf/DS-681.5.pdf
Bob... 04-09-2013 06:57 PM
Since it wasn't in the CEG Lite pdf file, I decided to call tech support. They said any paint solvent. I used denatured alcohol (did try vinegar and a few other things as well).
Seemed to do the job. Thanks for your help. :)
joecaption 04-09-2013 08:16 PM
And why did you not call the people that did the job and let them clean up the mess?
