Chipped Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 11:02 PM   #1
Chipped tile
I recently purchased 3x6 ceramic subway tile for a shower wall. Virtually every tile I recieved had a chip in one or more of the corners. The chips generally start at the bottom of the tile and extend upwards towards the glazed surface. While they are rarely visable from the surface, most chips are more than 1/2 the thickness of the tile. The supplier insists this is part of the manufacturing process and these chips are not a concern. I'm a little nervous about durability of these tiles, particularly in a wet environment. Also not sure grout will necessarily fill these voids thoroughly.
Should I be concerned, or are they legit?
Mr JJ
mr jj is offline   Reply With Quote
Old 05-04-2011, 05:16 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like a cheap tile---
You will most likely be fine--they are going on the wall and the modified thinset will give adequate support.
Are these bisque tiles (soft white body)?
Could you post a picture?---Mike---
Old 05-04-2011, 09:40 PM   #3
Mike:
Here's a photo. Hope you can make it out. Its not one of the best, but not one of the worst. Unfortunately not "cheap". It is white, but hard to say about the softness issue. Would you be comfortable installing these tiles in your shower?
mr jj
Old 05-04-2011, 10:20 PM   #4
Rewards Points: 558
Is that the back of the tile?
epson is offline   Reply With Quote
Old 05-05-2011, 05:17 AM   #5
Yes this is the back. The chips are not visible from the front, but do come close.
Old 05-05-2011, 05:31 AM   #6
DIY staff
They should be O.K.---I'd be returning them myself----Either poor quality control or careless handling.
Once installed the chips won't show or change,However I'd take that supplier off my list.--Mike--
Old 05-05-2011, 09:49 AM   #7
Rewards Points: 558
I would return them myself also...
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Removing a chipped tile on a current install JAN GM Remodeling 3 07-07-2009 05:55 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
