Ceramic Wet Saw Blade, Time To Replace? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 01:16 PM   #1
wraiththe's Avatar
Rewards Points: 97
Ceramic wet saw blade, time to replace?
Bought a used wet tile saw.
I think it is time to replace the blade. (thought it would be.)
This is a porcelain blade, I think a new one could do better, but it could just be my skillz or lack of. This is not the best cut I have made, it is the worst. (tests only.)
A new blade is expensive, but if it could do better, I want it.
What do you think?
Lowes down the block has a Dewalt long life 7" $49?
and a Koblolt ceramic 7" blade $39 ?
Ceramic wet saw blade, time to replace?-some-old-some-new-009.jpg   Ceramic wet saw blade, time to replace?-some-old-some-new-011.jpg   Ceramic wet saw blade, time to replace?-some-old-some-new-010.jpg
wraiththe is offline   Reply With Quote
Old 12-13-2011, 01:19 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That blade should still have plenty of life left in it. Sharpen it and see if things improve.
Old 12-13-2011, 03:15 PM   #3
wraiththe's Avatar
Rewards Points: 97
I am a little embareassed. (sp intended.) Did not know it was possible to sharpen a diamond blade like this. Only deglaze with a stone. Is that what you meant?
Old 12-13-2011, 04:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup!
Don't feel bad, a lot of people would have never guessed it.
Use a cement brick or block for best results.
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (12-13-2011)
Old 12-13-2011, 07:06 PM   #5
DIY staff
Rewards Points: 7,174
Check the alignment of the table to the blade---if the table is out of whack you can get chipping--
also --some glazes just chip--cut a sample from a different tile---see if the results are the same.
Old 12-18-2011, 02:50 PM   #6
Rewards Points: 340
what is the best blade for cutting porcelain?
kt82 is offline   Reply With Quote
Old 12-18-2011, 03:33 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A blade intended for use cutting porcelain.
XXX
Old 12-18-2011, 08:13 PM   #8
wraiththe's Avatar
Rewards Points: 97
Seriously... a blade that specifically says "Porcelain" on it.
You could use one for ceramic, but supposedly it will not work as well. Porcelain is considerably harder and it does tend to chip a little... esp if glazed. I chose the Dewalt Porcelain blade over the Kobolt porcelain one at Lowes. It said long life and was $10 more. I cannot tell you how any other blade would work. I can tell you that this one cuts through the tile very smoothly with very little chipping if any... and that dissappears after going over the cut edge with a stone.
The old blade in the saw I bought did not last very long.
I really like this blade.
Oh yeah... I have heard that split blades are not the way to go. The segments can get a little bent and cause a slight wobble.. which can cause more chipping with porcelain.
The Following User Says Thank You to wraiththe For This Useful Post:
kt82 (12-19-2011)
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
how do I attach ceramic tile to ceramic tile? porchhen9 Remodeling 8 07-31-2011 02:59 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
How to Replace a blade on electric saw jmdebb Tools 7 01-13-2011 01:48 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 08:40 PM
