Ceramic Tiles On A Diagonal Pattern.... - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 08:28 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
ceramic tiles on a diagonal pattern....
If I installed my ceramic tiles on a diagonal pattern, would it show less uneveness to the eye?
Since I have never done this before, I don't expect it to look great, so if I can "fool" the eye in some way, I would be good with that.......
Also, I have to slightly slope for drainage.
Thanks, I'm getting there.
(Is that baby here yet kc........, I'm in a hurry to finish this before he/she arrives.....)
yummy mummy is offline   Reply With Quote
Old 06-04-2009, 10:50 AM   #2
Newbie Bill
Rewards Points: 522
I don't have an answer for your question, but I am willing to bet it will look just fine and you won't need to be "fooling the eye".
Take photos!!!!
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-04-2009, 11:53 AM   #3
Thanks for compliment but I don't know about that......
This is the beauty of not knowing what I was getting into, when I said, "how difficult can it be to finish this basement".....
Old 06-04-2009, 11:53 AM   #4
I can't wait to take pictures!
Old 06-04-2009, 09:01 PM   #5
toolbelt Tina's Avatar
right back to you
Bravo! I share your pain and frustration in the enormity of the task. The tv shows make it look easy.
You can use a ledger board on the bottom to guide your tiles to perfect and straight line.
I obsess about the slightest imperfections but then after I realize it is futile as I am the only one who will know. And in the end you see the project in whole and not focused on one particular area.
Cheers to you.
Tina
toolbelt Tina is offline   Reply With Quote
Old 06-05-2009, 02:36 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depends on your viewing perspective but usually yes.
How about a "runninmg bond" to disrupt what the eye sees? Better than run-of-the-mill diagonal maybe.
Old 06-05-2009, 02:58 PM   #7
Old School
Willie T's Avatar
Here's the main problem with running tile floors on a 45. In anything but a perfectly square, equal sided room, you end up with trying to hide this kind of un-balance. You CAN finally work out a reasonable layout, but it's tough.
Willie T
Old 06-05-2009, 03:04 PM   #8
Thanks Bud. I am so glad to hear that, about the diagonal pattern, because I need all the help I can get.
What is "running bond"? Is it when you change size of tiles, and use different sizes?
By the way, Bud, I have just taken off all the paint on the concrete, (as you told me to) and I found a product called safe strip, that is enviro friendly, and has no odour and has worked fabulously for me.
A LOT, of work, but I am done, all 750 square feet of it.
Old 06-05-2009, 03:09 PM   #9
Old School
Willie T's Avatar
Tile laid in a running bond. Tile floors tend to lose some of the impressive effect of their "expansiveness" done this way.
Willie T
Old 06-05-2009, 04:14 PM   #10
Thanks Willie.
That pattern is another one that I was considering. I thought it was called brickwork pattern.
I may go with either one.
Old 06-05-2009, 05:34 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Running Bond/Brickwork Pattern - Toe-May-Toe/Toe-Mah-Toe
I'm going to disagree with that conclusion. When using a diagonal layout this hides a muriad of errors. The problem is each edge tile must be cut slightly different than the others and THAT is a PITA.
The straight lay patterns will show crooked walls a whole lot quicker than a diagonal pattern. With diagonal pattern you'll never notice the errors.
With straight lay you'll have a straight wall to compare the grout lines to. With diagonal you will not.
Old 06-05-2009, 07:48 PM   #12
Bud, my favourite tile guy......, tell me which one I should go with, and I will listen.
Old 06-05-2009, 07:55 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You could do a diagonal running bond and really confuse the eye.
Another plus for a diagonal lay is that most professional decorators will tell you it expands one's perception of a room, makes it look larger. I suppose that-too is argueable.
Let's go back for a minute! When you said in your first post:
Where you concerned about the room being out-of-square or where you referring to tile-lippage?
Old 06-05-2009, 08:39 PM   #14
I am not concerned about the room being square.
I am concerned about tile lippage. My brother in law just has his tiles installed by a professional and he has lippage. I figure, if the pro has lippage, I am going to have major lippage. (like Angelina Jolies lippage.....lol)
Old 06-05-2009, 10:26 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The flatter the substrate the better of course. The larger the tile the flatter the substrate needs to be.
So......what's the substrate like?
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 09:31 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Some of my ceramic tiles have no glaze abaker30 Flooring 2 03-13-2009 07:44 PM
Difference between difference ceramic tiles J187 Building & Construction 6 03-04-2009 12:17 PM
Ceramic tile on slab - install over adhesive left from vinyl tiles? softwareguy Flooring 1 08-23-2008 10:48 PM
