-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   ceramic tiles on a diagonal pattern.... (http://www.diychatroom.com/f84/ceramic-tiles-diagonal-pattern-45927/)
yummy mummy 06-04-2009 08:28 AM
If I installed my ceramic tiles on a diagonal pattern, would it show less uneveness to the eye?
Since I have never done this before, I don't expect it to look great, so if I can "fool" the eye in some way, I would be good with that.......
Also, I have to slightly slope for drainage.
Thanks, I'm getting there.
(Is that baby here yet kc........:laughing:, I'm in a hurry to finish this before he/she arrives.....:laughing:)
drtbk4ever 06-04-2009 10:50 AM
I don't have an answer for your question, but I am willing to bet it will look just fine and you won't need to be "fooling the eye".
Take photos!!!!
yummy mummy 06-04-2009 11:53 AM
Thanks for compliment but I don't know about that......:laughing:
This is the beauty of not knowing what I was getting into, when I said, "how difficult can it be to finish this basement".....:eek:
I can't wait to take pictures!
toolbelt Tina 06-04-2009 09:01 PM
right back to you
Bravo! I share your pain and frustration in the enormity of the task. The tv shows make it look easy.
You can use a ledger board on the bottom to guide your tiles to perfect and straight line.
I obsess about the slightest imperfections but then after I realize it is futile as I am the only one who will know. And in the end you see the project in whole and not focused on one particular area.
Cheers to you.
Tina
Bud Cline 06-05-2009 02:36 PM
Depends on your viewing perspective but usually yes.
How about a "runninmg bond" to disrupt what the eye sees? Better than run-of-the-mill diagonal maybe.:)
Willie T 06-05-2009 02:58 PM
1 Attachment(s)
Here's the main problem with running tile floors on a 45. In anything but a perfectly square, equal sided room, you end up with trying to hide this kind of un-balance. You CAN finally work out a reasonable layout, but it's tough.
yummy mummy 06-05-2009 03:04 PM
Thanks Bud. I am so glad to hear that, about the diagonal pattern, because I need all the help I can get.
What is "running bond"? Is it when you change size of tiles, and use different sizes?
By the way, Bud, I have just taken off all the paint on the concrete, (as you told me to) and I found a product called safe strip, that is enviro friendly, and has no odour and has worked fabulously for me.
A LOT, of work, but I am done, all 750 square feet of it. :eek:
Willie T 06-05-2009 03:09 PM
1 Attachment(s)
Tile laid in a running bond. Tile floors tend to lose some of the impressive effect of their "expansiveness" done this way.
yummy mummy 06-05-2009 04:14 PM
Thanks Willie.
That pattern is another one that I was considering. I thought it was called brickwork pattern.
I may go with either one.
Bud Cline 06-05-2009 05:34 PM
Running Bond/Brickwork Pattern - Toe-May-Toe/Toe-Mah-Toe:)
I'm going to disagree with that conclusion. When using a diagonal layout this hides a muriad of errors. The problem is each edge tile must be cut slightly different than the others and THAT is a PITA.
The straight lay patterns will show crooked walls a whole lot quicker than a diagonal pattern. With diagonal pattern you'll never notice the errors.:)
With straight lay you'll have a straight wall to compare the grout lines to. With diagonal you will not.:)
yummy mummy 06-05-2009 07:48 PM
Bud, my favourite tile guy......:wink:, tell me which one I should go with, and I will listen. :yes:
Bud Cline 06-05-2009 07:55 PM
You could do a diagonal running bond and really confuse the eye.:yes:
Another plus for a diagonal lay is that most professional decorators will tell you it expands one's perception of a room, makes it look larger. I suppose that-too is argueable.
Let's go back for a minute! When you said in your first post:
Where you concerned about the room being out-of-square or where you referring to tile-lippage?
yummy mummy 06-05-2009 08:39 PM
I am not concerned about the room being square.
I am concerned about tile lippage. My brother in law just has his tiles installed by a professional and he has lippage. I figure, if the pro has lippage, I am going to have major lippage. (like Angelina Jolies lippage.....lol)
Bud Cline 06-05-2009 10:26 PM
The flatter the substrate the better of course. The larger the tile the flatter the substrate needs to be.
So......what's the substrate like?:)
