Ceramic Tile On Stairs - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 04:35 PM   #1
ceramic tile on stairs
trying to figureout how to tile my stairs wich have a round nosing. figure i must cut them back , and am unsure how to bring the tiles together at the nosing of the stair, ( whether to but them or leave a grout joint or if there is special nosing for the stairs
sandsy is offline   Reply With Quote
Old 02-23-2012, 04:44 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Won't a bull-nose tile work?
Oh. Your treads are rounded off.
Might have to square those off to incorporate bull-nose tile.
I'm not a tile guy, wish I could help more.
titanoman is offline   Reply With Quote
Old 02-23-2012, 04:58 PM   #3
DIY staff
Rewards Points: 7,174
If these are concrete steps---you can do that---
If the staircase is wood---the installation will ,most likely,fail.
What do you have?
Old 02-24-2012, 08:08 PM   #4
long island, NY
also double check that removing the rounded part doesn't make your stairs too shallow / not up to building code.
diy'er on LI is offline   Reply With Quote
The Following User Says Thank You to diy'er on LI For This Useful Post:
oh'mike (02-24-2012)
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
Replacing Ceramic tile floor handy andy Flooring 4 03-28-2011 12:07 AM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-23-2011 11:04 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 10:01 PM
