Ceramic Tile Somewhat Uneven Basement Concrete Slab - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 11:23 AM   #1
Rewards Points: 24
So I'm ready to start prepping to lay down some tile on my basement floor 11'x20' room. I've been walking around the room with a cut spare piece of sheetrock as a level (8' length) and noticed there are definitely some waves to the floor (house built in 64'). It's kind of funny as if I lay the level down there could be a a little see-saw action where I might get anywhere from a 0.5" to almost a full inch gap. If I 'balance' the level I might get just a 0.5" average. The part that really stinks is there's definitely a bit of a dip at the entrance though not terrible, perhaps .25" or so. The entrance however is where it transitions to another room with a floor I don't plan on touching for a long time. What would be my best bet around this? I think 'fluffing' thinset might be a bit of a stretch. My buddy recommended a 3/4" trowel (12" tile) anyways due to the concrete in addition to using some leveling compound in the bad areas.
Should I use the SLC and if so would I just try to feather it as best as possible where the room transitions to the floor at the entrance? With the SLC and the thinset and the tile I fear a decent sized height difference here. Should I just use SLC on the whole room as well instead of patch work? I got the buckets, the heavy duty drill and mixer so I could do it properly. Just read some not so great experiences with SLC and was curious if its more trouble than it's worth. Also, for the edges of the room I have wood paneling that goes half way up the wall. Would I just use some painters tape as a barrier from the SLC? Thanks!
knight508 is offline   Reply With Quote
Old 10-09-2013, 03:01 PM   #2
DIY staff
Rewards Points: 7,174
If the floor is that wavy ,use the SLC---I've used plenty over the years---read the directions---and follow them---remember--you must push the product around --and not waist any time---
Old 10-15-2013, 04:23 PM   #3
Rewards Points: 24
I ended up using the SLC Levelquik RS and it was "okay". Still have a couple trouble spots but overall it sort-of worked out to a "good enough" state. I wasn't really impressed at all by the "self leveling" properties. I felt as though I added a touch more of water, say 8oz. to the whole pail it would have worked better but I chose to follow the directions exact. Definitely have the floor squeegee ready to spread.
The Following User Says Thank You to knight508 For This Useful Post:
oh'mike (10-15-2013)
Old 10-15-2013, 06:03 PM   #4
DIY staff
It's a learning curve----You do need to get it almost level with a trowel or rake---then it will flow out flat----
I use Jifset---never had an issue----
Tags
compound , leveling , slc , uneven
Uneven concrete basement floor problem Novice_Minty Flooring 8 02-18-2013 11:21 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Want to Install Ceramic/Porcelain and Insulate Basement Slab illusion8055 Building & Construction 2 08-15-2012 01:19 PM
Problem with concrete floor prep for ceramic tile install tdon7 Flooring 8 11-30-2011 10:12 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
