Ceramic Tile Repair - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 11:33 AM   #1
Ceramic tile repair
Hi guys, I just recently had my foundation repaired and in the process I have a hairline crack in a couple of the kitchen floor tiles. Is their a quick fix for this or does the tile need to be replaced? Thanks again.
matt13 is offline   Reply With Quote
Old 01-09-2013, 11:39 AM   #2
Rewards Points: 2,516
Crack in the grout or crack in the actual tile?
hammerlane is offline   Reply With Quote
Old 01-09-2013, 11:47 AM   #3
It's the tile
Old 01-09-2013, 05:53 PM   #4
Rewards Points: 14,312
There is no "fix". They need to come out and be replaced.
Remove the grout, crack the tile in an X pattern with a brick chisle, remove the tile, clean up the floor and use thin set to set new tiles.
Old 01-09-2013, 06:00 PM   #5
Thanks joe, that's what I thought. I figured I better ask before I start bustin tiles up! Thanks again.
Old 01-10-2013, 05:23 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This is step #2.
Step #1 is locate replacement tiles. If you don't have a couple of extra tiles in the garage or somewhere, find replacements before you start breaking up the old ones. A tight hairline crack may be easier to live with than a bad match.
Tile over existing ceramic tile jgb29 Tiling, ceramics, marble 4 03-26-2012 11:50 AM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
replacing tile on durock, how to repair part of durock board already on floor? gared@roadrunne Tiling, ceramics, marble 1 01-15-2011 05:01 PM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
