Ceramic Tile Over Painted Basement Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 03:07 PM   #1
Ceramic Tile over painted basement floor
My older house has low ceilings in the basement! (6'7") and I would like to finish the floor with ceramic tile.
At some time, in the past the floor was painted. With what type of paint, I have no idea? There is no chipping or flaking!
My question is will the tile adhesive bond to this surface? Or will it come loose?
Old 05-01-2010, 08:40 PM   #2
DIY staff
Rewards Points: 7,174
You said that the paint is in good shape and showing no signs of failure--
If the paint is holding well--I say go ahead--For good measure use the best thinset available.
For this I suggest using unmodified powder with liquid latex.
You would probably be fine using modified thinset,but for the little extra cost I would feel safer with the liquid latex added.---Mike--
Old 05-01-2010, 11:44 PM   #3
Thanks for the quick reply, Mike! This paint appears to be quite old, but is well bonded to the concrete.
Rather forming a coat, it appears to be melded into the concrete!
Are there paints for concrete that attaches to concrete, in same manner as mortar does?
Old 05-02-2010, 07:04 AM   #4
DIY staff
Floor paints and why some hold up and others fail is a mystery to me-----
I think the condition of the concrete --before the paint goes on--- has every thing to do with the success.
I've had two part epoxy peel off --and $10.00 Wallmart porch paint remain perfect for 15 years--
It's a mystery-------------Mike-----
Old 05-02-2010, 04:14 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Be aware that the tile installation industry STRONGLY DISCOURAGES installing ceramic tile over a painted concrete substrate. Painted surfaces are known bond-breakers when it comes to ceramic tile installations - doesn't matter how you cook the thinset.
Coatings should be removed by mechanical means, no chemicals. Shot-blasting, sandblasting, and grinding are the methods used.
XXX
Old 05-02-2010, 11:28 PM   #6
Yes, this is/was my concern! Trying to clear the paint off isn't going to happen!
I'm thinking of using DELL dimpled underlay, topped with laminate!
I considered tile in case of flooding, that was the only reason!
Old 05-02-2010, 11:51 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just sayin'!
XXX
Old 05-03-2010, 05:50 PM   #8
Just sayin'!
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Tile over basement concrete floor? BowDown Flooring 2 05-08-2009 09:41 AM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
Ceramic Tile over basement floor KHB Flooring 4 03-14-2008 12:58 PM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
