-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Ceramic Tile over painted basement floor (http://www.diychatroom.com/f84/ceramic-tile-over-painted-basement-floor-70298/)
Wildie 05-01-2010 02:07 PM
My older house has low ceilings in the basement! (6'7") and I would like to finish the floor with ceramic tile.
At some time, in the past the floor was painted. With what type of paint, I have no idea? There is no chipping or flaking!
My question is will the tile adhesive bond to this surface? Or will it come loose?
oh'mike 05-01-2010 07:40 PM
You said that the paint is in good shape and showing no signs of failure--
If the paint is holding well--I say go ahead--For good measure use the best thinset available.
For this I suggest using unmodified powder with liquid latex.
You would probably be fine using modified thinset,but for the little extra cost I would feel safer with the liquid latex added.---Mike--
Wildie 05-01-2010 10:44 PM
Thanks for the quick reply, Mike! This paint appears to be quite old, but is well bonded to the concrete.
Rather forming a coat, it appears to be melded into the concrete!
Are there paints for concrete that attaches to concrete, in same manner as mortar does?
oh'mike 05-02-2010 06:04 AM
Floor paints and why some hold up and others fail is a mystery to me-----
I think the condition of the concrete --before the paint goes on--- has every thing to do with the success.
I've had two part epoxy peel off --and $10.00 Wallmart porch paint remain perfect for 15 years--:laughing:
It's a mystery-------------Mike-----
Bud Cline 05-02-2010 03:14 PM
Be aware that the tile installation industry STRONGLY DISCOURAGES installing ceramic tile over a painted concrete substrate. Painted surfaces are known bond-breakers when it comes to ceramic tile installations - doesn't matter how you cook the thinset.
Coatings should be removed by mechanical means, no chemicals. Shot-blasting, sandblasting, and grinding are the methods used.:)
Wildie 05-02-2010 10:28 PM
Yes, this is/was my concern! Trying to clear the paint off isn't going to happen!
I'm thinking of using DELL dimpled underlay, topped with laminate!
I considered tile in case of flooding, that was the only reason!
Bud Cline 05-02-2010 10:51 PM
Just sayin'!
Wildie 05-03-2010 04:50 PM
Originally Posted by Bud Cline (Post 436837)
Just sayin'!
:wink:
