Ceramic Tile, Over Linoleum, Over Concrete ??? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 06:32 PM   #1
Ceramic Tile, over linoleum, over Concrete ???
Hello,
Can you install ceramic tile over a linoleum floor that is glued down to concrete?? Is so is there any special ways of doing it?
Mike
dhpa15 is offline   Reply With Quote
Old 07-29-2009, 05:56 AM   #2
Over concrete, yes, but linoleum or vinyl would act as a cushion and could cause tiles or grout cracking.
Old 07-30-2009, 02:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
REMOVE THE VINYL.
ALWAYS remove the vinyl.
Old 01-21-2010, 06:51 PM   #4
the reason for the bump is I have removed the vinyl which was glued to the slab tho it came up easily. I am left with residue and some paint overspray are these bond breakers, do i need to get down to the concrete or can I skim the foor with a product and then come back and tile. this is in a bath. thanks
Old 01-21-2010, 07:50 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sorry about this answer but...yes and no.
Paint on a concrete floor in the form of overspray from painting walls is generally do-able if it isn't too thick and the grainy surface of the concrete is still present.
In the case of adhesive residue that also depends. If the adhesive was black and has now been scraped away so as to leave nothing more than a serious stain then there are modified thinset mortars that can be used over this adhesive residue. Usually the thinset bag will say so. The black adhesives are referred to as "cutback" adhesive and that is generally the term used.
If the adhesive is any other color it could be a water-based adhesive. Some water-based adhesives won't present a problem after they have cured (they can't be reimulsified) but some very well could present a problem. So...the thing to do in that case is to throw a small amount of water on the floor (adhesive) and let it stand for thirty minutes or so. If it turns a lighter color and is slimy to the touch, it must be removed. If it isn't removed it will do the same thing when it is under the thinset and the thinset won't bond to it or the floor.
XXX
Old 01-22-2010, 07:24 AM   #6
thanks, sorry I got bumped offline last night ice and snow took out connection. Think what I will do is clean floors to concrete and put in backerboard to be safe. do i want unmodified under backer?
Old 01-22-2010, 03:06 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You cannot install backerboard over concrete. That is yet another
Bag-O-Worms you won't want to deal with.
If you were to use a quality "modified thinset" you'll be fine.
XXX
Old 01-29-2010, 06:50 PM   #8
Ceramic Tiles
Creating layers is never a good Idea when installing tiles. The more layers you have the more trouble. It is always a good Idea to rip out the old floor. You might discover new problems mold/rotting etc
Last edited by Gary in WA; 02-03-2013 at 09:00 PM. Reason: removed ad link per forum rules.
ittnyc1 is offline   Reply With Quote
Old 01-29-2010, 07:56 PM   #9
Originally Posted by dhpa15 View Post
Hello,
Mike
Are yoiu the same person as the original poster ?
Old 01-29-2010, 08:08 PM   #10
different -was doing search and his post as close as i could find
Old 01-31-2010, 11:59 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
tpolk: "different -was doing search and his post as close as i could find "
Sorry but that makes no sense to me.
XXX
Old 01-31-2010, 01:12 PM   #12
not same person as original poster if i understood daves question
Old 02-01-2010, 10:14 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ah-h-h-h!
XXX
Old 02-07-2010, 07:46 AM   #14
Rewards Points: 4,752
elec grinder w/7" diamond turbo cup wheel, dust shroud, & wet/dry vac all rentable from an apron store
Can I ceramic tile over linoleum? havetime_4fun Flooring 20 12-30-2011 06:29 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
putting down ceramic tile over old linoleum adhesive waltdisney Flooring 3 03-27-2009 11:41 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
