Ceramic Tile Over Lath And Plaster Wall? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 12:17 AM   #1
Wounded Mathematician
shtoink's Avatar
ceramic tile over lath and plaster wall?
I am about to prepare to install a wood stove in a corner in my 100 year old house. The stove will be positioned at an angle in the corner and all necessary clearances will be met. I intend to install ceramic tile about 4 feet up the 2 walls in this corner. These walls are lath and plaster and are flat and smooth. The plaster seems to be in good shape.
What (if anything) do I have to do to prepare these walls for installation of tile? Any advice regarding this installation is appreciated.
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 05-01-2010, 06:42 AM   #2
DIY staff
Rewards Points: 7,174
I'd be a little worried about the stability of 100 year old plaster---
However--If you're confident that the plaster is good--I would use unmodified thinset with a liquid latex additive. That will give you maximum sticky and flexibility.
I guarantee that will stick to the antique walls--There is a good possibility that the old paint or plaster might give up--but the thinset will not.--Mike--
Old 05-01-2010, 07:25 AM   #3
i would consider spacers with long screws into the framing thru durorock,then tile that
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
oh'mike (05-01-2010)
Old 05-05-2010, 05:50 PM   #4
shtoink's Avatar
Thanks for the advice!
I think I will put up durock first and install the tiles on that. I have thought about the weight of the tiles and don't want to risk failure of the plaster.
tpolk - you recommend spacers behind the durock - is this a heat shielding consideration?
For aesthetic reasons, I would prefer to have the durock directly on the wall - screwed into the studs. If directly on the wall, would a thinset or adhesive make a difference or would screws be sufficient?
G.K. Chesterton
Old 05-05-2010, 07:42 PM   #5
the spacers help to limit heat transfer, allows for venting. you could finish edges and leave top open
Old 05-05-2010, 09:29 PM   #6
DIY staff
The Durrock can be screwed to the wall without any additional stick-um behind it. That would make removing the thing easier in the future.
Be sure that you use thinset to install the tiles--mastic might not hold up well to the temperatures.
I heat my house with a wood stove--I just use the furnace as a back-up.
TPOLK's suggestion of adding spacers is excellent--Just nailing --or screwing--1x2 vertically every 12 or 16 inches--like an ordinary furring strip--will allow you to get the tiled surface quite hot without worry about the actual plaster getting to hot.
--Mike----
mounting things on lath and plaster walls wilderstyle General DIY Discussions 11 01-17-2010 08:48 AM
Lath & Plaster Wall Box/bracket winesmile Electrical 10 03-03-2009 07:26 AM
Lath & Plaster Wall Box winesmile Building & Construction 2 12-03-2008 01:58 PM
Finding studs in a lath and plaster wall Oilerz Remodeling 8 03-02-2008 11:52 PM
Bathrrom Tile, Plaster Quinnman Building & Construction 1 09-12-2006 07:43 PM
