-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   ceramic tile over lath and plaster wall? (http://www.diychatroom.com/f84/ceramic-tile-over-lath-plaster-wall-70266/)
shtoink 05-01-2010 12:17 AM
I am about to prepare to install a wood stove in a corner in my 100 year old house. The stove will be positioned at an angle in the corner and all necessary clearances will be met. I intend to install ceramic tile about 4 feet up the 2 walls in this corner. These walls are lath and plaster and are flat and smooth. The plaster seems to be in good shape.
What (if anything) do I have to do to prepare these walls for installation of tile? Any advice regarding this installation is appreciated.
oh'mike 05-01-2010 06:42 AM
I'd be a little worried about the stability of 100 year old plaster---
However--If you're confident that the plaster is good--I would use unmodified thinset with a liquid latex additive. That will give you maximum sticky and flexibility.
I guarantee that will stick to the antique walls--There is a good possibility that the old paint or plaster might give up--but the thinset will not.--Mike--
tpolk 05-01-2010 07:25 AM
i would consider spacers with long screws into the framing thru durorock,then tile that
shtoink 05-05-2010 05:50 PM
Thanks for the advice!
I think I will put up durock first and install the tiles on that. I have thought about the weight of the tiles and don't want to risk failure of the plaster.
tpolk - you recommend spacers behind the durock - is this a heat shielding consideration?
For aesthetic reasons, I would prefer to have the durock directly on the wall - screwed into the studs. If directly on the wall, would a thinset or adhesive make a difference or would screws be sufficient?
tpolk 05-05-2010 07:42 PM
the spacers help to limit heat transfer, allows for venting. you could finish edges and leave top open
oh'mike 05-05-2010 09:29 PM
The Durrock can be screwed to the wall without any additional stick-um behind it. That would make removing the thing easier in the future.
Be sure that you use thinset to install the tiles--mastic might not hold up well to the temperatures.
I heat my house with a wood stove--I just use the furnace as a back-up.
TPOLK's suggestion of adding spacers is excellent--Just nailing --or screwing--1x2 vertically every 12 or 16 inches--like an ordinary furring strip--will allow you to get the tiled surface quite hot without worry about the actual plaster getting to hot.
--Mike----
