The condo association is requesting that I install cork for sound proofing and also install a 1/2 wood underlayment over the concrete floor before installing the ceramic tile in the long hallway. I am pretty handy and can do this work. However, I don't understand why the wood underlayment, but that is the rules here. So what is the process of installing this, thin set, cork , thin-set, wood underlayment. but how would the underlayment be attached to the concrete floor, use a tongue and grove underlayment. Do I run screws into the concrete to secure before installing the tile. Has anyone come across this and had it installed. Please any information will be greatly appreciated.
Use cork panels (6mm-9mm) not rolled cork. Install with urethane adhesive to keep elevations low and provide a little moisture resistance. Then install the tile with modified thinset.
Forget about all of that other nonsense, you are on the wrong path there.
Alternatives are Noble's CIS Membrane and Schluter DITRA Mat.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
