Ceramic Tile Backsplash - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 07:22 PM   #1
Ceramic tile backsplash
Can I lay the mastic for my tile backsplash in my kitchen directly over drywall covered in old latex paint? Do I need to seal any drywall repairs before tilling? Any suggestions?
sychopants is offline   Reply With Quote
Old 11-15-2010, 07:31 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
Hi sycho,
You can and should install the tiles direct onto wall board on dry areas such as a backsplash. Mastic is fine for this application. Paint is fine as long as it's not glossy and clean. If you used drywall compound, it's a good idea to either prime (but let cure) or better yet shim coat with adhesive prior to applying the adhesive.
What type of adhesive were you planning to use? Is it highly absorbent ceramic, porcelain or stone tiles?
Jaz
Old 11-15-2010, 09:25 PM   #3
I am still debating over small glass tiles of varying color or stone, I haven't quite made up my mind yet! My old laminate back splash has old painted drywall under it, I don't think it's glossy. I am a little concerned about the old back splash tearing at the wall when I go to rip it out, I have some left over Gardz from a wall I stripped, would it be a good idea to use that on the wall before tilling(after any repairs)?
Old 11-16-2010, 03:51 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
You can't use mastic if you go with glass tiles. I don't know about Gardz. You should remove the laminate and then report back.
Jaz
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 07:56 PM
