-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Ceramic plank tile installation question = More Difficult than standard tile? (http://www.diychatroom.com/f84/ceramic-plank-tile-installation-question-more-difficult-than-standard-tile-158885/)
gtothek 10-03-2012 08:59 PM
I'm planning on putting in ceramic plank tiles that mimic hard wood flooring. One of the contractors I had in for an estimate said he charges more because it's a more tedious installation, and needs more time to lay the tile. He said this isn't a novice job, because you don't want to show a lot of grout lines, so that it mimics the hard wood floor look. Is this legit, or is he trying to take me for a ride? I have laid tile before, I put down travertine last year in my powder room bath. I would just like to hear your thoughts, and if I should consider doing this myself, or if it really is harder than regularly shaped tile flooring.
joecaption 10-04-2012 07:54 AM
No harder then any other tile, just needs a perfectly soild floor and flat subfloor so the long skinny tiles do not crack.
gtothek 10-04-2012 07:57 AM
The one contractor said that the tiles really need to butt up against each other, and that its not an easy job for a novice. Is that true? Is it just more time consuming, and could that be why he would charge more?
JazMan 10-04-2012 08:30 PM
I gotta disagree with Joe. The contractor is right, those planks will take more time to install and if the floor isn't real flat it'll also not turn out as good as smaller tiles. Any tile 15" or larger is considered large and is more difficult to work with. Butting tiles together with little or no gap is not recommended and will only increase the degree of difficulty. excessive lippage may be a problem unless the substrate is very flat.
Jaz
gtothek 10-04-2012 09:42 PM
The tile planks are 24"x 6". To get the look of hardwood, what grout line size should be used? 1/16, 3/32? Should I leave this to the contractor, or try it myself? I want it to look good, so not sure if I should do it.
oh'mike 10-04-2012 09:48 PM
One more thing--the long planks are usually dished a bit---causing lippage problems---Jaz had a good description of the safest setting methods on a thread some time ago----
Jaz?
gtothek 10-04-2012 09:54 PM
What do you mean by "dished a bit"?
JazMan 10-04-2012 11:08 PM
[QUOTEgtothek]What do you mean by "dished a bit"?[/QUOTE]
All large tiles have a tendency to be warped a bit in the manufacturing process, sometimes more than others. So the center is curved up more than the ends, higher in other words. When setting large rectangular tiles it's best to offset the rows about 1/3 instead of 50% as in an running-bond pattern. (brick). This will minimize lippage because of the tile.
In addition, the industry recommends no grout line be less than 1/8" wide and that is if the quality of the tiles are high. Tiles are not always the same size.
Jaz
gtothek 10-05-2012 08:46 AM
Thanks Jaz. Do you think DITRA is a better underlayment than backboard for this type of tile? Is there a difference?
JazMan 10-05-2012 07:53 PM
Yes, absolutely, I highly recommend Ditra over backer boards.
Jaz
