Ceramic Floor Tile WITH NO THIN SET. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 03:56 PM   #1
I installed ceramic tile without thin set. I attached the hardiebacker board to the plywood and then spread a grout/adhesive combo to the floor. I set the tiles and about an hour later used the remainder of the grout/adhesive mix to grout the tile. Should I be concerned?!
Crey13 is offline   Reply With Quote
Old 05-04-2011, 08:06 PM   #2
any good tile guy will tell you the only place to use mastic is on a wall that doesnt get wet. they could tell you how long til you start having problems.
was your floor really flat?
Old 05-04-2011, 08:14 PM   #3
Rewards Points: 81
You used grout as an adhesive, or was it some kind of special product?
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 05-04-2011, 08:57 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A bit more information might help.
Can you be more specific than "grout/adhesive combo"? What specific products?
Exactly how did you attach the hardiebacker board to the plywood?
How large of an area? Where: kitchen, bath, entryway?
I'm curious how were you able to come back in an hour and not only "grout" but clean up the tiles without messing up or shifting them?
Old 05-05-2011, 08:55 AM   #5
It doesn't sound like the floor will hold up for very long. Did you install the Hardie per the manufacturer's instructions by mortar bedding it, and using the correct screws, with correct spacing? Modified thinset is what you want to use when installing ceramic floor tile, the kind you mix, that comes in a bag, not in a bucket. Just my opinion.
littlecleo is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Add 2 ceramic fixtures to existing switch diyneedshelp007 Electrical 4 03-01-2010 01:28 PM
Thin set vs mastic/glue for ceramic tile ph3iron Flooring 6 02-17-2009 07:56 AM
