Cement Board Under Bullnose? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 09:36 PM   #1
Cement board under Bullnose?
Hi all,
I'll be installing cement board in the shower and was curious how far out cement board should be installed so that the bullnose tiles properly bond to the wall? Can I leave about an inch of drywall so that the bullnose covers the seam between the cement board and drywall? If this is recommended, will thinset bond to drywall or must I use a different adhesive on half of the bullnose to ensure it bonds to the drywall? The reason for leaving an inch or so of drywall is because it is already texture and painted....
Jay2013 is offline   Reply With Quote
Old 07-06-2013, 01:56 AM   #2
Rewards Points: 4,780
You can overlap the tile onto drywall as much as you want. Thinset and tile bond to drywall just fine. Not necessarily through the texturing though. I would scrape off the texturing in the area, depending on what kind of texturing it is and how well it's adhered to the wall.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
oh'mike (07-06-2013)
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
how to hang plastic behind shower cement board 4just1don Building & Construction 2 07-22-2011 12:34 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
