Cement Board For A Tile Shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 05:37 PM   #1
Cement board for a tile shower
We have our vinyl liner down and have put the bottom half of our cement board down. We only left 1/4 between the bottom liner and the board will this be okay or do we need to take it down and cut it? We are having to build our bed up more because of the drain.
Melissa11 is offline   Reply With Quote
Old 12-04-2011, 05:53 PM   #2
did you do a preslope under the liner? did you put blocking between the studs to support the liner? did you install a vapor barrier behind the cement board or do you plan to waterproof over the cement board?
The Following User Says Thank You to DannyT For This Useful Post:
Bud Cline (12-04-2011)
Old 12-04-2011, 06:16 PM   #3
DIY staff
Rewards Points: 7,174
Typically the rock goes in before the final deck mud is packed in---this holds the bottom of the rock in place---
I'm including a link to building a hand packed shower base----see how this compares to your work--
Building a shower pan with pre-sloped mortar bed, liner and curb.
ben's plumbing (12-04-2011)
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
bathtub vs. cement board for tile amakarevic Flooring 6 11-14-2011 06:46 PM
Master Bath Floor and Shower Tile. frankie_dee Tiling, ceramics, marble 11 05-23-2009 06:08 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 02:20 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
