Cement Board On A Slab? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-13-2013, 05:10 AM   #1
Rewards Points: 91
Cement board on a slab?
I have an a little over an inch to make up and am wondering if I can use a layer or two of cement board to do this or if it is better to use a dry pack. I will be making up the difference then laying heat mat on top and covering with self leveling. The floor consists of 1" he. Mats
2 ways to accomplish this=
1. Dry pack the mat and self leveling to proper subfloor height
2. Instal cement board right on the slab then heat mat and self leveling to proper height. I thought of skimming the floor with thunder then setting the board in this and if 2 layers needed buttering thin set on this and turning the sheet perpendicular....
I think the board is faster/cheaper and easier but don't know if its ok to do. First time laying this type of floor and looking for easiest best way for positive results
gwilkrrs is offline   Reply With Quote
Old 11-13-2013, 05:34 AM   #2
DIY staff
Rewards Points: 7,174
Cement board over a slab is not a good plan---attaching it without voids or lippage is not likely-----
Deck mud is time consuming,but dependable----
Old 11-13-2013, 08:12 AM   #3
Rewards Points: 91
Fair enough- that seems to be the answer- I guess I was looking for an easy answer- the lack of math and ease of time and energy-- the area isn't huge but big enough (5'x15'). Does deck mud calculate the same for coverage as say concrete?
Old 11-13-2013, 06:03 PM   #4
DIY staff
Sure it does----very inexpensive to mix your own---masons mortar is often used for a job like that----and premixed deck mud is available at many tile stores.
I use a cement mixer (I own one) for a really consistent mix---you can achieve the same results by hand mixing-------
Old 11-13-2013, 07:29 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
Originally Posted by oh'mike
.....masons mortar is often used for a job like that----and premixed deck mud is available at many tile stores.
NO NO NO! Mike, surely you didn't mean to write "premixed" deck mud. I'm sure you meant to say "preblended" in bag, ready to be mixed. Premixed will be interpreted as it's already in paste form and we don't want that.
Mason's mortar is ok for walls and shower curbs where a sticky paste is what you want. Floors get deck mud which is sand/cement only.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
GBrackins (11-13-2013)
Old 11-13-2013, 09:14 PM   #6
DIY staff
OOPS----Poor choice of words----Listen to Jaz------
Old 11-14-2013, 07:20 AM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Well you can get a bag of deck mud- drypack mortar OR sand and topping mix to achieve deck mud. Nothing with latex in it and make sure it's damp when finished mixing.
JetSwet is offline   Reply With Quote
egads, do I need to rip out my cement board and start again? soberjulie Flooring 38 06-28-2013 10:27 AM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 06:55 PM
cement board on top of cement brim in washroom avi Remodeling 9 09-08-2011 07:05 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
