Cement Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-02-2015, 11:30 AM   #1
Rewards Points: 2
Cement board
I am putting a surround in and put plastic underlayment on then the cement board. Was planning to seal the cement board with Redgard. What will happen if I do that? or is the underlayment of plastic enough?
Don1956 is offline   Reply With Quote
Old 10-02-2015, 04:48 PM   #2
Rewards Points: 14,312
What type? Glue on, Nail on?
Both do not need tile board behind them.
A glued on only needed green board sheet rock no vapor barrier.
Nailed on needed nothing behind it.
Old 10-02-2015, 08:55 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Joe,
I think you may have misunderstood Don's question/situation.
Don,
It is not recommended that you have both the plastic on the studs and a surface membrane too. The surface membrane would have be better, but too late now. Continue without the Redgard using a good modified thinset to bond the tiles.
Can you give some info on the tiles and the adhesive you plan to use?
Jaz
Old 10-28-2015, 01:06 AM   #4
Rewards Points: 978
yea i am a bit confused on the question too. i take it he means a surround for the bath tub/shower?
federer is offline   Reply With Quote
Plunge cut cement board - or not? miamicuse General DIY Discussions 5 11-13-2013 08:58 PM
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 03:16 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 04:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 06:17 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
