-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   cement backer board or not? (http://www.diychatroom.com/f84/cement-backer-board-not-101890/)
Jroberts8192 04-17-2011 04:12 PM
I want place new tile over existing tile for my hearth. I have a 1920's home, the existing tile cannot be removed because that is all there is there. I am extending the tile out onto the old hardwood about 6". do I need backer board to do this? I don't want to put it down because we upgraded to a sealed gas fireplace and I would have to adjust the height of it if I place the backer board- I would only have to slightly adjust the hieght of the front facing without the backer board. If I don't put the backer down will my new tile crack?
Bud Cline 04-17-2011 04:59 PM
...the existing tile cannot be removed because that is all there is there.
How can that be? I suspect there is another reason.:)
You can not install tile over hardwood and you can't really install backerboard over hardwood and expect the tile to last.
Extending the tile over the hardwood while depending on whatever is supporting the tile elsewhere may also not be a good thing.:)
MCTF 04-17-2011 05:34 PM
magic tile that sets itself in thin air? I would remove the tile.
Ron6519 04-18-2011 04:06 PM
The tile is sitting on a concrete base. If you want to extend the tile, you need to extend the concrete base or something of equal structural value.
The tiles will come off with a little effort. If you want the job to last, I suggest you expend the effort.
Ron
Bud Cline 04-18-2011 09:27 PM
The tiles will come off with a little effort. If you want the job to last, I suggest you expend the effort...
Ron
There ya go.:)
Crossing over two different substrates using a single tile is probably a mistake.:)
