10-16-2009, 10:30 AM
#1
Can marble tiles be cut by scoring and snapping them?
Before I purchase marble tiles, I was wondering if I can use my ceramic tile cutter, that scores and snaps the tile?
Also, can nippers be used on marble tiles?
10-16-2009, 11:43 AM
#2
Licensed Builder
Marble is a stone usually cut with a tile wet-saw. Marble is also stronger than ceramic. I don't think your method will work. I could be wrong though..
10-16-2009, 07:08 PM
#3
Wet saws and diamond blades dry or wet on a grinder, NO snap cutters.
It is?
10-17-2009, 11:03 AM
#4
Thanks a lot for the info. I guess I will switch the type of tile that I was going to use, as I really don't want to buy a tile saw.
10-21-2009, 07:02 AM
#5
marble has no ' grain ' therefore can't be snapped,,, why anyone'd want to use marble's beyond me, tho - this is concrete !
10-21-2009, 08:18 AM
#6
registered
Rent one for the day. Wouldn't be that much.
10-21-2009, 11:01 AM
#7
I think I will do that, because I really want to put in marble tiles just behind the pedestal sink from the bottom all the way up to the ceiling. Approx. 2 1/2 feet by 8 feet.
The saw that I would rent, I imagine would be a wet saw. Ok, now this really sounds like a dumb question but I imagine I have to hook it up to a hose or something? Would it not make a complete mess because of the water. Or do I have to do the cutting outside.
Maybe I should go back to my original idea and change tiles. ......
I probably slice a couple of fingers while I'm at it.......
Is there not a hand saw for this type of tile? Just wondering......
10-21-2009, 11:06 AM
#8
itsreallyconc
The concrete flooring looks great!
I really like it. But my marble would not be on the floor. I would never use marble for the floor.
Just a sort of decorative feature in my powder room, and at the same time, prevent the wall just behind the pedestal sink from water splashing paint chipping, etc.
10-21-2009, 12:56 PM
#9
Jack of all - master none
Wet saws are not very complicated to use. The wet saw I borrowed before simply looked like a mini-table saw, that had a tray of water under it. The blade would spin through the water under the cutting table, and thus be wet. You'd have to empty the tray of sludge/debris and refill the water every once in a while.
It was a cheapo saw that I borrowed, but it got the job done.
10-21-2009, 06:04 PM
#10
I have used a mitre saw before.
I thought that you may have had to attach a hose to it........
thus creating a mess.
Thanks for the info.
10-21-2009, 06:16 PM
#11
The good ones have a water pump in the tray, but all of them should be set up outside, if you can only cut inside, you will have to rig up something to contain the over spray and the water that falls off the tile and on to the floor as they are cut.
10-27-2009, 06:53 PM
#12
They are messy...easy, but messy. The little rubber flapper behind the blade stops a lot of the spray, but not all of it, so you may get a little racing stripe on a wall if you are doing this inside. Best to set up outside.
I've been doing my "project" between my day job and sleeping, so I don't always have big blocks of time. My project is nearing the end, but I have left myself with some tiling...kitchen back splash (95% complete), entry floor (done), front porch, and bathroom shower. Most things are nice and square, square tile...should be easy. Along comes the designer (wife)...oh, no, these need to be at a 45, oh, and all these corners need to be trimmed for the accent tiles, and the arch behind the stove in the backsplash, and.....Needless to say buying a used tile saw on craigslist and selling it for close to what I paid for it makes far better financial sense than renting a saw for what I need. Owning the saw I can work at my own (slow) pace.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
