Can Liquid Nails Be Used To Add Tile Rows Above Tub/shower - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 02:53 PM   #1
Rewards Points: 89
Can liquid nails be used to add tile rows above tub/shower
So I got the walls tiled up to about 6 feet and looked to finish the wall abobe it and decided maybe shoulda went all the way up. There is green board up already and I dont want to take it down and add backer. Is it good to put tile up there with liquid nails? will it hold? and then grout over it. should I or even can I use thinset on the green board instead?
If tiling over the green is not good then I will paint or maybe sheet goods. It might sound a little uncaring or Mickey mouse but just want to finsh now. i have learned a lot and expect my next bathroom job to be much nicer Much Much nicer. Dont realy want people to know I did this one.
papason is offline   Reply With Quote
The Following User Says Thank You to papason For This Useful Post:
oh'mike (12-15-2012)
Old 12-15-2012, 03:24 PM   #2
DIY staff
Rewards Points: 7,174
Thinset will work just fine with the greenboard---some like to prime the board first---I never have --and that never caused me trouble---
Forget the liquid nails---way to slow to set---thinner than thinset---and much to messy and expensive----It would work---but more trouble that it's worth---
JazMan (12-15-2012)
Different tub/shower tile question MikeKy55 Tiling, ceramics, marble 14 07-31-2011 12:54 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Liquid nails for crown molding? Artie2 General DIY Discussions 6 07-18-2008 08:36 PM
Getting rid of 'liquid nails' on brick l1r Remodeling 5 04-30-2008 10:57 AM
screw down roof. Can I use Liquid Nails too? aberezin Roofing/Siding 2 11-18-2007 05:45 PM
